Old 04-05-2009, 10:54 PM   #391
Send a message via Yahoo to motojon
Had a great time racing/testing today with Sam and Nigel. Learned a lot about the set-up and the affects of different changes. Lap-times are getting more and more consistant. Thanks again Sam and Nigel
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 04-06-2009, 01:25 AM   #392
Send a message via ICQ to CivicTuning
i have almost built my 966 and i must say quality-wise it is the worst Serpent i have ever built.
Axles not fitting perfectly like they should. I had to drill larger holes in plastic, etc etc.
Not something i am used to !!
Just my 2 cents.
Greetz.
Christoph.
CivicTuning is offline   Reply With Quote
Old 04-06-2009, 04:48 AM   #393
GMartinez's Avatar
Trader Rating: 83 (100%+)
Just my 2 cents.
Greetz.
Christoph.
When I built my 966 the axles had a tight fit but not to the point that it needed to be filed down. no drilling needed in my recent build
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 04-06-2009, 04:49 AM   #394
captian's Avatar
Originally Posted by TEAM BROOKLYN View Post
Brooklyn hobbies will have them monday april 6th !
what's this !!! richie you coming over to the dark side
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-06-2009, 04:53 AM   #395
captian's Avatar
mines went together real well had no problems .its just been sitting to long .
Old 04-06-2009, 06:09 AM   #396
I guess i had a kit that was made on monday, lol.
I solved everything myself with a little work, so i hope it drives well.
Greetings,
Christoph
Old 04-06-2009, 06:29 AM   #397
stefan's Avatar
Send a message via AIM to stefan
Just my 2 cents.
Greetz.
Christoph.
You are not alone.
I just finished my son's 966, the first ever Serpent in my household.
As a long time Mugen driver I was totally shocked by the amount of work, it took to get this car together.
- Front sway bar did not slide together, had to be ground to fit
- Front arm hingepins did not go through without reaming
- Pressure bearing in clutch missing
- Steel rolls in 2-speed missing
- 1 wrong rear upright (OS1 instead of OS2)
I am sure I missed some stuff.
I hope the car will run better than it went together.
stefan is offline   Reply With Quote
Old 04-06-2009, 06:45 AM   #398
AddictedToRacin's Avatar
He Stefan,
your son will also drive 1/8?! I'm really looking forward to race with him.
AddictedToRacin is offline   Reply With Quote
Old 04-06-2009, 07:15 AM   #399
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
Just my 2 cents.
Greetz.
Christoph.
the way i remem ber it, was serpents required alot of massaging to get them right, at least the old school cars...vector etc.havent heard anything on new cars yet tho..untill now that is!!/..lol..stil kick ass cars tho..always were and im sure they still are, it was explained to me a awhile back, that its much better to lightlly 800 grit sand parts for your custom fit, and than they wear in, than get parts with little or no slop,,but need to be changed more often because of this,, u know r.c bud...its all about COMPROMISE,,,unless u buy a XRAY of course...LOOL
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 04-06-2009, 07:15 AM   #400
Originally Posted by stefan View Post
You are not alone.
I had some of your problems as well.
I ddin't mention everything either.
I even opened a shock and the plastic ring with 3 holes was simply missing !
Lucky i had some from my old 960 '08.
Greetz,
Christoph.
Old 04-06-2009, 08:02 AM   #401
ALG
You are not alone.
I bet that the person that put the parts on the bag had "Personal problems" or wake uo with the left foot ajajjaja
I never had problems with SERPENT kits.
Sefan your son with enjoy the 966!!!
Have fun
ALG is offline   Reply With Quote
Old 04-07-2009, 02:21 PM   #402
Angry
You are not alone.
Definetly not alone, mine had missing middle pulley holder ( but an additional middle shaft ? ) Missing rear anti roll bar bearings, missing front axle shims, split in the plastic on one of the front antiroll bar holders, some missing screws for the radio plate, missing 1 pillow ball for rear upper arm to upright. Front antiroll bar needed grinding to fit the ball in the socket and a lot of additional work on freeing suspension pins etc.
eigthracer is offline   Reply With Quote
Old 04-07-2009, 02:51 PM   #403
JFCJ's Avatar
Trader Rating: 31 (100%+)
Default My Build
I recieved my kit last week; and so far, it has went together flawlessly. I did some minor polishing and reaming, but nothing unexpected. The only challenge I've had so far is pressing the inserts in the rear carbon fiber for the upper arm pin. Their longer than the carbon fiber is wide. I don't want to take pliers and bugger up the insert... so I'm trying to find a outward press type tool for the job. Any suggestions would be appreciated. Those things are tight!
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Old 04-07-2009, 03:03 PM   #404
R/C Unlimited of San Jose just recieved one today.$659.99 jump on it before its gone!!!
RC_UNLIMITED is offline   Reply With Quote
Old 04-07-2009, 03:21 PM   #405
A friend and I just ust a soft material that was hollowed out a little and put over the hole and used a hammer and lightly tapped it through
My Gpa(RIP)
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
