Old 03-25-2009, 02:24 PM   #331
Thank you Nigel!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 03-25-2009, 03:03 PM   #332
Originally Posted by nigelnuggets View Post
If your 960 was free, then why do you say there was drag? Use your logic Michael!
And do you REALLY feel the difference in the coefficient of drag between the old braking system and the new?
Whatever, anyway... Mr. Cupps, your previous 960 08' in comparison to the new 966 share the same geometry, so to answer your question, start with your setup from last years biggie and work from there!
Many of us are running Green front and Pink/Red rears. All new springs btw. But start from there!
yes I do, simply put when you let off the brake's the pad's are spread apart
do to the spring, instead of the pad's and disc having to work themselves
apart, and when the car is in the corner the pad's will not push against the
disc, do to centrifugal forces yes my car was extremly free as you know,I
also used spring's to help keep the pad's apart however the new way is is
way better, the differance of cg on the old, was minor as the only
differance was that the pad's were rotated which would mean only a small
part was moved below the center line , now that might be logical , lol.
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 03-25-2009, 06:50 PM   #333
Team Kamikaze's Avatar
Default 966 Brake System
Hmmm,
Maybe this will re-freshen your memory, please read:
Brake-system
The brake system ensures strong and efficient stopping power. The brake pads consist of two steel plates with the friction material pre-baked to the plates, and the brake disk is made from twin ventilated discs with an air-cooling alu centre.
The new braking system sits lower in the car to help LCG. The system is easily accessable for maintenance, due to its very open design.
The spring-loaded bar-pads slide on polished steel pins and are activated through the ball-raced brake cam, a large pin moves horizontally to activate the brakes. Due to the horizontal action of the pin, and not the twisting of the brake cam, all distortion in this area is removed and the brake pads are evenly pressed together. The brake cam is supported by ball-bearings for smooth, precise action.
This further adds to the precision and exceptional stopping power of the braking system.
Brake 966
Lower mounted brake-assembly for lower LCG. Spring-loaded brake-plates slides on polished steel shafts. Ready-to-run brake plate/pads assembly with new friction brake material. The ball-raced hard anodized brake-cam push the 2 larger pins which are seated in the aluminium bracket, against the brakeplat, to create very smooth and even pressure to the plate.
SOURCE: http://www.serpent.com/product/903009
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-25-2009, 07:22 PM   #334
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by J-MAN View Post
Thank you Nigel!
Good luck to you this weekend Jeremy, i hope all goes well ill PM you my PH# if you need help over the course of the weekend, but you know you can always reach Paolo if necessary!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-25-2009, 09:07 PM   #335
Thank you! I cant wait to run the new car! This week has taken forever to go buy!
Jeremy Cupps
Sponsors are
Old 03-26-2009, 07:42 AM   #336
Originally Posted by Team Kamikaze View Post
Hmmm,
Brake-system
Brake 966
I have seen that too, So? what do you think made a bigger differance
on the car the , that the pad's were rotated 90 degrees so that less then
1/2 the mass ( 4 grams? ) was moved or that the new pad's are smaller
and are spring loaded?
Old 03-26-2009, 08:54 AM   #337
You still don't understand the whole concept of the car do you? did you even READ what is posted? or you only look what is posted? TK posted a very good information about the new brake system of the 966, so READ!
ich weiß
hello is offline   Reply With Quote
Old 03-26-2009, 09:06 AM   #338
M7H
M7H's Avatar
Well, I have to agree with Michael there, i mean how much difference does 4 grams make for the CG...
But you are a person that if it is written, it has to be true?...
I also like to think further, just like Michael does....
Serpent
M7H is offline   Reply With Quote
Old 03-26-2009, 09:09 AM   #339
Send a message via Yahoo to motojon
Lwr cg is always better end of story
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 03-26-2009, 09:42 AM   #340
have you ran both car's if you have, and you look at it closely then you
would know, what it is i am talking about , I am not saying that moving it
has no effect on cg but the working part effects the car more and that
together the sum of all parts, this is the best yet
Old 03-26-2009, 10:02 AM   #341
nitrodude's Avatar
Is the car fast? Yes!! Is it better than the 960? Yes!
Then who gives a flying monkey turd why? It seems some people just want to argue. Just give it up already people!!! The car is effing fast!!!!!!
Shees!!! Its pissing me off!! And those of you who know me know how hard it is to piss me off!!!
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-26-2009, 10:27 AM   #342
+1
My Gpa(RIP)
Old 03-26-2009, 10:30 AM   #343
It's not a argument ,and we should be done with it now.
Old 03-26-2009, 02:01 PM   #344
You guys can handle all the technical aspects of the car, ill step out of this thread.
Old 03-26-2009, 02:28 PM   #345
Nigel if i remember correctly you did realy well with the car at the winternats, Im listening to you my freind!
Jeremy Cupps
Sponsors are
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
