Old 03-24-2009, 10:21 AM   #316
M7H
M7H's Avatar
Originally Posted by MugenDrew View Post
Yeah and I wish you well...
Yep, real race cars are made from Aluminium and carbon fibre, not only from plastic...
But still, nothing wrong with a Mugen, a fast car it is, but I can understand you guys getting bored, because you can never buy something new for your car... and see the result, you sneak over to the 966 thread...
And please, this is really meant as a joke!....
Serpent
M7H is offline   Reply With Quote
Old 03-24-2009, 02:50 PM   #317
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
Originally Posted by michael 1 View Post
Also , with the new braking system the whole car feels like it has been freed
up it seem's to carry more speed everyware on the track.
The purpose of the new braking system was the lower the center of gravity since the pads are below centerline. The previous braking system was fine and the car was still very free. So the repositioning of the braking system aids slightly in handling!
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-24-2009, 05:03 PM   #318
the brake pad's are fairly lite, however having the brake pad's separated
by spring's free's the drive train from parasitic drag ,which of course
will allow the car to carry more speed in the corner's and every where else
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 03-24-2009, 09:11 PM   #319
Who the hell are you? you got balls to argue with Nigel? correct me if I were wrong, Nigel have more wins under his belt than you, that means he have more knowledge with the car than you and I don't even know if you have ever won or at least finish on the top 5 or at least top 30 on a major race, so if I were you to avoid humiliation I would stop.
by the way I still have my 960, and the brakes never is an issue, it never drag the drive train.
ich weiß
hello is offline   Reply With Quote
Old 03-24-2009, 11:55 PM   #320
stefan's Avatar
Send a message via AIM to stefan
Who the hell are you to deny the guy his own opinion?
Maybe he's Michael Salven, who knows
Das ist aber nicht gerade die neutrale Schweizer Art
stefan is offline   Reply With Quote
Old 03-25-2009, 12:51 AM   #321
LOL
Anywhoos, Michael, you saw my old 960'08, and i think it was fairly evident that "Parasitic drag" did not exist whatsoever.
Yes of course springs to keep the brake pads separated will keep them from dragging, but you have to remember that the brake disc isn't fixed as it floats on the pins as well as the 2 speed shaft, so theoretically this "drag" still exists. So the previous design of having the plastic ring around the bulkhead/brake lever to keep the braking system from engaging by keeping it in the open position would still maintain its "free-ness." Plus before the old design allowed for all 3 moving parts to float freely which would probably create the same amount of "drag" as the new system does.
So, with that information, I'm pretty sure the braking system was designed for CG.
The reason why the new car is so free, is because of the precision in the new aluminum parts used in the drivetrain assembly.
Old 03-25-2009, 02:21 AM   #322
M7H
M7H's Avatar
But Nigel, You have to admit the 966 brakes different then the 960...
Serpent
Old 03-25-2009, 05:18 AM   #323
I never once said the 960'08 and 966 brake in the same manner. With the materials used in the 966's brake pads, the stopping power is much stronger right off the bat. But once the pads have worn in and hot spots are created on the rotor, the feel is very much the same.
Besides, when you drive your car, do you not change your chassis' braking setup to suit you and your driving style? So of course my car will feel the same as my previous.
Old 03-25-2009, 09:12 AM   #324
It doe's not matter who I am , It is just my opinion, nigel and myself go back
a few year's, you I dont know
Old 03-25-2009, 09:21 AM   #325
LOL
It is true , that the disc , would float but the pads would also move
back and forth in the corners causeing drag, and yes cg was a factor
as was the spring and the way the cam was reworked , I belive it is a sum of
all part's that make this the best serpent yet. and Nigel you know
my 960 was super free
Old 03-25-2009, 10:02 AM   #326
Send a message via Yahoo to motojon
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 03-25-2009, 10:39 AM   #327
gotmotor's Avatar
Who's DICK you sucking, you one of Nigels SIP SIP boys......lol
gotmotor is offline   Reply With Quote
Old 03-25-2009, 12:28 PM   #328
If your 960 was free, then why do you say there was drag? Use your logic Michael!
And do you REALLY feel the difference in the coefficient of drag between the old braking system and the new?
Whatever, anyway... Mr. Cupps, your previous 960 08' in comparison to the new 966 share the same geometry, so to answer your question, start with your setup from last years biggie and work from there!
Many of us are running Green front and Pink/Red rears. All new springs btw. But start from there!
Old 03-25-2009, 12:29 PM   #329
Lol there is only one set of lips on my Serpent homie...
Old 03-25-2009, 01:43 PM   #330
gotmotor's Avatar
Quit talking about me........slurp
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
