Old 03-18-2009, 11:13 AM   #286
dbl
dbl's Avatar
Originally Posted by Team Kamikaze View Post
We will be at C P this Sunday, will dial in Dindo's 966, bring your car too, so we can do the final adjustment on your clutch.
Originally Posted by nigelnuggets View Post
Joel Esguerra and Dindo Laroya looked really good with their Serpent 966's today!
Thanks to Sam & Nigel for always helping me out with my car. The 966 really accelerates hard and really sounds mean! I just hope I can learn to drive mean!
dbl is offline   Reply With Quote
Old 03-18-2009, 11:58 AM   #287
A few questions here:
I'm using the Xceed #103022 brake disk and I have a lot of play in between the brake pads on my 966.
The brake cam that rotates on 2 speed standoff came with a short allen screw in the bottom on it.
Should this screw be used in the brake cam?
How can I eliminate the excessive spacing with brake disks to ensure the brakes work properly?
Thanks.
Kendall is offline   Reply With Quote
Old 03-18-2009, 12:23 PM   #288
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
In my experience there really isn't a clearance problem on the braking system. But, if you really need to, shims can be applied on the collars that the brake pads slide across.
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 03-18-2009, 12:50 PM   #289
Hi Nigelnuggets,
Thanks. Shims should help.
Did your brake cam come with a small screwed into it at the bottom.
The manual does not show any screw at all. I don't think I need to but just looking to make sure.
Old 03-18-2009, 01:18 PM   #290
My brake cam has a screw in it also, to me it looks like its their to take some space out of the assembly. I have my car already built and i checked the brakes out and everything works perfectly fine with the screw!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 03-18-2009, 02:07 PM   #291
Team Kamikaze's Avatar
Originally Posted by Kendall View Post
Hi Nigelnuggets,
The small allen screw is there to prevent the brake cam from over rotating back wards, it's there for precautions only, it will not interfere with the operation of the brakes at all.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 03-18-2009, 02:19 PM   #292
Thanks for the help everybody.
Old 03-18-2009, 02:28 PM   #293
GMartinez's Avatar
Trader Rating: 82 (100%+)
+1 for GMartinez!
+2 A little getting used to the shocks for me but once the shocks are done correctly it's a breeze & very consistent rebound.
The 966 is gonna make a lot of us very lazy the only change I did from the Winternat's for the Kissimmee track was red springs rear & slightly harder oil in the rear
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is online now   Reply With Quote
Old 03-18-2009, 07:22 PM   #294
Hey let me have some "HARDER" oil
Old 03-18-2009, 07:26 PM   #295
GMartinez's Avatar
How Hard lol
Old 03-19-2009, 07:24 AM   #296
M7H
M7H's Avatar
This is how it looks on my car, with the standard break discs, You have more play?
http://www.mijnalbum.nl/GroteFoto-IGEJBYP6.jpg
As stated by Sam, the screw is to prevent the break to rotate the other way, and applying breaks while at full throttle....
it is an "aftermarket" screw.
Serpent
M7H is offline   Reply With Quote
Old 03-19-2009, 10:22 AM   #297
I got everything to work. I had to make sure the pad was sliding over the bushing that holds it in place. After I did that I had no problem after testing it with my radio gear. Thanks.
Old 03-19-2009, 02:10 PM   #298
M7H
M7H's Avatar
Yep, this is a bit difficult when assembling, but be sure they move freely, or you don't have a brake at all.....
Serpent
Old 03-19-2009, 09:57 PM   #299
What springs should I keep for the 966?
ioxqq is offline   Reply With Quote
Old 03-19-2009, 10:32 PM   #300
The whole set of Serpent springs (New and Old)
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
