Serpent 966
#2236
I clean up and test run it yesterday night the 2speed shift .... Thanks Dan_Vector and Rick Davis for the great help.... Only thing now my centex clutch engage delay maybe cause I using the cheap trackstar engine from HobbyKing .... Will save up to get the novarossi engine
#2237
#2238
Well done glad you've sorted it. The Novarossi ISON is a great budget engine and will last you a fair while as long as you look after it! Build your clutch exactly as per the manual and you'll have a perfect starting point. 0.6mm end float and adjusting nut 1.5 turns out from fully tight.
