Old 12-11-2012, 10:34 AM   #2191
nitrodude's Avatar
Originally Posted by GREGORY! View Post
what is their geometry difference??
It puts the axle further away from center of the car.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 12-11-2012, 01:37 PM   #2192
GREGORY!'s Avatar
i don't get it!
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 12-12-2012, 11:24 AM   #2193
Hi people,
I am currently running the front hubs with larger bearings, is this ok? If I was to use the small bearings with eccentric housings what position should I run them in and what effect would it give? Also, with regard to the hubs being marked 1 and 2, I am using No1 on the right. What effect does it have if I were to swap them.
Thanks in advance
JIM1 is offline   Reply With Quote
Old 12-16-2012, 10:05 PM   #2194
sm4100's Avatar
Send a message via Skype™ to sm4100
Originally Posted by JIM1 View Post
Hi people,
Thanks in advance
I don't see any problem in running bigger bearings, just more mass to turn around but more solid and long lasting than the small original ones. Many pro racers do that. Just make sure your belt is not too loose or too tight.
Regarding the eccentric position, they only adjust the belt tension that's it because they put the inner axle forth or back.
I have heard so many tech theories about the position of the eccentric but honestly I believe they just strach or loose the belt nothing else. The position of the front wheels will not change with the eccentric carrying the one way, unless we are talking about the wheel hub eccentric.
1 and 2 stands for left and right but in this case I think you are talking about the whell hub right?
sm4100 is offline   Reply With Quote
Old 12-18-2012, 11:49 AM   #2195
Thanks for your reply sm4100.
I was referring to the eccentric adjusters when using the small front hub bearings.
I have never experimented with them so was wondering what effect it has on the handling.
Sorry for any confusion.
Old 12-23-2012, 12:59 PM   #2196
LOW ET's Avatar
Trader Rating: 95 (100%+)
what over all length are you guys running on the rear shocks when setup to use the carbon shock mounting point extensions on the arms?
what spacers are you guys running on the updated rear end, none, rubber, or aluminum?
what's the hot body to run?
LOW ET is offline   Reply With Quote
Old 12-26-2012, 09:38 PM   #2197
I am looking for used 966īs in good condition (in both nitro and E).
Rollers or complete.
Send a PM
AlvaSpeed is offline   Reply With Quote
Old 01-23-2013, 09:23 PM   #2198
nitrodude's Avatar
While I await the release of the 977 Viper, I still have my 966 to run. Does anybody know what distance from the bumper do we mount the Protoform R18, Ive only ran the Blitz R18
Steven Muller
Ronin Speed Parts
Old 01-24-2013, 02:23 AM   #2199
M7H
M7H's Avatar
go for 18-20mm
Serpent
M7H is offline   Reply With Quote
Old 01-24-2013, 06:09 AM   #2200
sm4100's Avatar
Originally Posted by M7H View Post
go for 18-20mm
+1
Old 02-01-2013, 01:11 AM   #2201
GREGORY!'s Avatar
Can someone tell me the part number for the long rod ends like for use with rear suspension extension kit. The hard ones that has the word:top on the one side.
Old 02-17-2013, 11:28 AM   #2202
LOW ET's Avatar
anyone using the savox 1251 servos with lipo and no regulator? how's that working out?
Old 02-17-2013, 11:34 AM   #2203
ogreasurada's Avatar
Not sure about 1251 but I have been using 1258 with lipo w/o reg and they work perfectly.
ogreasurada is offline   Reply With Quote
Old 02-17-2013, 11:54 AM   #2204
LOW ET's Avatar
nice!
Old 03-13-2013, 06:28 PM   #2205
rc-goods's Avatar
Default EVO-Workshop 966 7075 T6 Hardcoated Chassis (EVO-966-ESE903323)
Pre-Order
www.rcgoods.com
rc-goods is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
