Old 10-18-2012, 01:35 PM   #2176
GREGORY!'s Avatar
Originally Posted by Rick Davis View Post
Think most racers are just running without the front brace , I ended up cutting the ears off and just using the center to make the assembly easier because the bulkheads and spool drop in as a unit.
i see.have you notice any diff with and without the front mount?how about the anti-scuat setting?what can it do for the rear end?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 10-18-2012, 01:58 PM   #2177
Toughbeard's Avatar
For those interested I have 2 TE V2 kits in stock left. 600USD plus S/H.
Cleaning warehouse I have alot of spares as well.
contact me at serdar.aytemiz@evilrc.com for assistance.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 10-19-2012, 02:18 PM   #2178
Hi guys
What effect on handling should I get when I add shims to raise the rear upper wishbone? I have been running with 2.5mm but have not ever ventured into the effects of changing it.
Also, I am going to try the pfr18 body. I was going to mount at 20mm, is this ok?
Thanks!
JIM1 is offline   Reply With Quote
Old 10-19-2012, 08:10 PM   #2179
nitrodude's Avatar
Originally Posted by JIM1 View Post
Hi guys
Thanks!
You'll get more steering, it makes the rear of the car rotate more.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 10-21-2012, 03:26 PM   #2180
blanks596's Avatar
Trader Rating: 14 (100%+)
like this?
http://youtu.be/HEB20qrP73s
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 11-04-2012, 12:02 AM   #2181
gday guys, wondering if anyone could help me, my last few outings i have been loosing my circlip to my middle pulley on the front oneway,its happened 3 times in a row,driving my nuts,its the 7mm circlip,this also makes me strip my front belt and pulley,im running out of spares.anyone else have this,or is it just me.
cheers burty
burty is offline   Reply With Quote
Old 11-04-2012, 04:04 AM   #2182
Toughbeard's Avatar
cheers burty
Which E ring are you loosing.... its all 7 mm e clips on the middle shaft.
it can be because all is too tight fit...
Serdar Aytemiz
Old 11-04-2012, 10:23 AM   #2183
gday toughbeard,sorry bud ,should have been more specific,its the smaller inside pulley on the middle shaft. cheers for any help.
burty.
Old 11-04-2012, 12:44 PM   #2184
nitrodude's Avatar
Throw it away and get an aluminum pulley and a new clip.
Steven Muller
Ronin Speed Parts
Old 11-04-2012, 03:03 PM   #2185
sounds like a plan nitro,cheers bud,should have done it from the start,just another quick one,is it normal for the uprights to rub slightly on the inside of my rims,getting slight gouging on all 4 corners.setups as per default with a couple of changes to springs and oil.
cheers burty.
Old 11-04-2012, 10:41 PM   #2186
nitrodude's Avatar
Yeah, that's normal, don't worry about it
Steven Muller
Ronin Speed Parts
Old 11-22-2012, 12:28 AM   #2187
rc-goods's Avatar
Default Zero Force Serpent 966TE Bearing Kit Set
Zero Force Serpent 966TE Bearing Kit Set (16pcs) (ZF-N12005)
www.rcgoods.com
rc-goods is offline   Reply With Quote
Old 12-10-2012, 07:05 PM   #2188
Does anyone know the difference 903351 and 903257 for 966? Upright 966 W2 vs Rear upright OS2?
emule2010 is offline   Reply With Quote
Old 12-10-2012, 07:32 PM   #2189
bcebwecb's Avatar
The W2 gives more initial steering, it makes the car more "twitchier" and therefore harder to drive. Try both of them to see what fits your driving style, cause everyone's is different
Brandon Cho
1 Corinthians 10:31
_______________________________________________________________________________
Team ARC USA - Hobby Authority Distribution - TiTAN BLITZ - Prolevelrc
bcebwecb is offline   Reply With Quote
Old 12-11-2012, 06:31 AM   #2190
GREGORY!'s Avatar
what is their geometry difference??
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
