Serpent 966
#2161
gday there guys,whats everyone use for a pinion tool?? does the mugen one work,i cant get hold of the serpent one here,they say its discontinued. noob question sorry.
cheers burty.
cheers burty.
#2162
http://www.evilhobbyshop.com/Gear-Pi...h,PR-2052.html
but the Mugen one works as well.
the main differences:
Mugen aluminium Serpent Plastic.
Mugen holds on to one tooth, Serpent fits over snuggly and holds all teeth
Mugen expensive, Serpent Cheaper
#2163
Hello All,
Does anyone know where I can purchase the Central Lola body manufactured by Serpent?
http://www.redrc.net/2007/02/serpent...la-body-shell/
Tried ashford, kamikaze, etc w/ no luck.
Your help is greatly appreciated. Thanks for looking.
#2164
Got my 966 shipped to me Saturday and cant wait to get it on the track, Question I do have for you Serpent Bro's is about the rear body mount. I heard that some are using the MRX-5 rear mount, so what is the reason to change to an MRX-5 part on a Serpent ?
#2166
#2167
The car doesn't need anything as it comes from the factory, everything is top notch, no aftermarket needed. There's a couple of things that are nice to have though. A set of aluminum pulleys and the aluminum upper deck mount. The upper deck mount is just a tunning option. That's about it
#2168
#2170
We have an end of the year warehouse clean up. get your spare parts at 20% discount...
Send us you wish list and we will make it come true...
[email protected]
[email protected]
#2171
They use the mugen mount with mounting collars because it's easier to remove than the serpent with the 2 mm clips
The quick fix is to dill holes throught the mount over the mounting pin locations and use a grub screw to hold
Mounting rods in place. Kinda ala Capricorn/ Kyosho
Also u put a nice flat spot in the rods for the grub screw to flatten out on just don't over tighten and strip the plastic
#2172
16T Pulley
Hi,
I need for a prototype project, the pulley dimensions (measures) of the Serpent 966 or 960.
If you have an electronic caliper, can you give me the dimensions ( millimeters ) of the 16T pulley.
Can you give me those ones (the 4 narrows colors) ?
Excuse me for my poor english...
Thanks,
Bye !
My project :
http://www.rctech.net/forum/electric...onversion.html
Thanks,
Bye !
My project :
#2173
hey guys,i have the original 966.i mod the rear camber mount so i can use the rod style from TE and anti-scuat set up.now.i must remove the one camber mount that is not used or i must have the v2 aluminum bulkhead to remove it and avoid excessive rear flex?
#2174
#2175
Think most racers are just running without the front brace , I ended up cutting the ears off and just using the center to make the assembly easier because the bulkheads and spool drop in as a unit.
