Old 07-19-2012, 11:24 PM   #2131
Originally Posted by Serpent-Dan View Post
Paolo will you be in the office tomorrow?
I'm @ Timezone
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 07-19-2012, 11:43 PM   #2132
Phil Trotta's Avatar
Originally Posted by Paolo M View Post
Hi Guys and welcome Phil to the Snake Pits...
Serpent has uploaded some of my latest 966 TE Setups. You can check them out here:
http://serpent.com/product/903011/setups/
Paolo grazie per l'aiuto il mio amico
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 07-20-2012, 05:05 AM   #2133
and23's Avatar
Yes...... Rumors. I can tell you that there is no new car in September. Our 2012 car is the 966 TE.
Andrea, non credere a tutto quello che senti in Italia.
OK, grazie.
Andrea
Serpent 733
Max RR3
and23 is offline   Reply With Quote
Old 07-20-2012, 05:50 AM   #2134
I have a question for the racers in here. Technically, this could be asked of any brand car... but I figured there would be a greater majority of posters in this thread who had seen the RedRC "Pro Tips" series w/ Michael Salven. I don't race gas on-road anymore, only electric... and predominantly pan-cars(12th, WGT etc). So, you will have to bear with me here. I was watching the first Salven video: http://www.youtube.com/watch?v=pjecRkYoT6M
At about the 5 min mark or so, after he lubes the front driveshafts and re-installs them, he goes about re-attaching the upper arm mounts to the front bulkheads. Salven places a 2mm shim under the front of the upper arm mount. This effectively tilts the upper arm hinge-pin/axis of rotation backwards. Being a pan car racer, I am very familiar with reactive caster... it is a very useful tuning aid and can be the difference between a great car and one that is hardly drivable. However, the typical dynamic caster that is used on pan-cars sets the upper arm rotational axis at an angle forward... not back. So what Salven is doing is effectively using "reverse" reactive caster from what is typically used on pan-cars, etc.
Now, what confused me was Salven's subsequent explanation for this modification. He mentions that the "reverse" dynamic caster gives "better turn-in" and responsiveness @ corner entry, without sacrificing steering later in the corner.
This is basically, verbatim, what "normal" reactive caster does. When the upper arm axis of rotation is angled forward, the caster angle decreases as the front suspension compresses. Thus, at corner entry when you lift off the throttle or tap the brakes, the load is transferred to the front suspension... compressing it and reducing the caster angle(standing the steering hub up in a more vertical configuration) and giving more steering at turn-in. At corner exit, however, as the suspension begins to extend, the caster angle progressively increases... thus aiding in corner-exit steering.
By using the "reverse" reactive caster, Salven is setting the car up so that it gains caster as the suspension compresses. This makes sense, as a few seconds later he mentions that this allows him to run a smaller static caster angle, as he hates the way the car feels with lots of caster. But... if the front suspension caster angle increases as the suspension compresses, you will end up with lots of caster @ turn-in, making the car sort of numb and un-responsive... and much less caster @ corner exit, taking away some of the steering there as well.
With the electric pan cars, we have only ever used the "normal" reactive caster. Can someone explain the reasons for using the "reverse" reactive caster on any car? All I can come up with is that it would make a twitchy over-steering car easier to drive... But that is basically the opposite of what Salven is saying. So... is Salven's explanation incorrect? Or is there something I am missing here?
JamesL_71 is offline   Reply With Quote
Old 07-20-2012, 06:24 AM   #2135
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
one thing you have understand is pan car front suspension has fixed bottom arm and the steering block pin is pivoting with the pivot ball thats why reactive caster is happen, with gas car it will not have reactive caster because top and bottom arm are moving up and down at the same time so only have static caster
tl2111 is offline   Reply With Quote
Old 07-20-2012, 07:42 AM   #2136
Salven specifically states that the purpose of placing the 2mm shim under the upper arm mount is to create dynamically changing caster....
Old 07-20-2012, 11:57 AM   #2137
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I'm @ Timezone
Ok. I will give you a call during the later part of next week. Good luck lets have a repeat of last year! Top step!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 07-20-2012, 03:57 PM   #2138
The tire contact patch changes with different angles on the upper hinge whether being positive or negative and will give different traction characteristics throughout the turn ...
It is easy enough to try for yourself and make your own conclusion/ theory.
Even on the bench turning the wheel left to right while creating weight transfer you can see differences in contact patch try it
PHIL TROTTA
Old 07-20-2012, 04:36 PM   #2139
Can someone explain the reasons for using the "reverse" reactive caster on any car? ........ Or is there something I am missing here?
The way 4WD 1/8 on-road gas cars are typically driven. Unlike electric cars, our cars have rear solid axles, so we make our cars change direction not just with turning the front wheels but at the same time applying throttle to place the rear end; ie. throttle steering.
Very rarely we rely on off power steering as a rear solid axle creates too much drag, so we power our cars into, round and out of corners, or at least hold on to or 'feather' the throttle to get the amount of rotation we need.
peppernick is offline   Reply With Quote
Old 08-05-2012, 01:13 PM   #2140
I like the body mount changes M.S and Sabrina did to their cars at the EC
Old 08-05-2012, 06:12 PM   #2141
I saw that too. Is it to increasae front end flex ?
Old 08-06-2012, 12:03 PM   #2142
Well the word from M.S to me was the rear mounts are more stable and the front was for weight balance. He was trying to get more rear weight
Old 08-14-2012, 06:41 PM   #2143
rip67vdub's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to rip67vdub
Default Help! Looking for the Central Lola body
Hello All,
Does anyone know where I can purchase the Central Lola body manufactured by Serpent?
http://www.redrc.net/2007/02/serpent...la-body-shell/
Tried ashford, kamikaze, etc w/ no luck.
Your help is greatly appreciated. Thanks for looking.
rip67vdub is offline   Reply With Quote
Old 08-14-2012, 08:43 PM   #2144
That's gonna be hard to come by as it's been out of production for about 4-5 yrs. plus the newer shells provide more performance. Best bet is eBay and over seas. Wish you luck.
Old 08-14-2012, 09:13 PM   #2145
rip67vdub's Avatar
Thanks again Dan. I wanted to adventure out on some old school bodies, but I guess I'll have to resort to perhaps some of the Blitz bodies.
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
