Old 07-05-2012, 07:03 PM   #2101
Originally Posted by bcebwecb View Post
Has anyone tried to put an angle on the upper bracket by adding or removing shims? Can anyone tell me what that would do to the car?
it will have reactive caster, brandon cho
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 07-05-2012, 09:00 PM   #2102
bcebwecb's Avatar
Thank you Mr. Shing, see you soon
Brandon Cho
_______________________________________________________________________________
Team ARC USA - Hobby Authority Distribution - TiTAN BLITZ - ActivRC
bcebwecb is offline   Reply With Quote
Old 07-07-2012, 05:20 AM   #2103
Paulie Bee's Avatar
Default Angle on front hangers
Your right Michael.
So in practical terms on the track, contact patch is in fact dynamic throughout the turn. Soooo, raising front of the hanger, gives more corner entry but lose a little corner exit. The opposite occurs by raising rear of the bracket helps corner exit. You really need to try these back to back without chaning anythging else. I suggest a 2mm difference from front to rear spacers under the hangers and test to really feel the difference.
Paulie
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 07-07-2012, 06:46 AM   #2104
lastsun's Avatar
Notice from the setup posted at serpent site that some of them are using anti-squat setting at the rear lower arm holder. What are the effect? If I am now using both at the lowest position, how do I set for anti-squat? And also what is the mean diff using the older radio plate link flex and the new TE front flex?
I am still running the EVO version and am considering changing to TE V2, but dun like the look of the TE front-end.
Serpent 966 EVO / OS MAX
lastsun is offline   Reply With Quote
Old 07-07-2012, 10:14 PM   #2105
Phil Trotta's Avatar
Thumbs up Anti squat
TUNING WITH ANTI-SQUAT
Most vehicles allow the adjustment of Anti-Squat in similar ways: somehow adjusting the height of the front or rear hingepin mounts of the rear suspension arms.
Adding Anti-Squat will make the car Squat less during acceleration. This will cause your car to track straight on straightaways. It will also make your car push coming out of corners, but loose entering corners.
Less Anti-Squat will result in the opposite: a little less forward traction, more stable entering corners, and will track through bumpy sections much better.
Since your running your pins low already move the inner pin holder to middle this would be putting anti squat in. ...
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 07-07-2012, 10:19 PM   #2106
Since you already have your pins low raise the front pin eccentric to middle mount and you'd be puttin anti squat in
PHIL TROTTA
Old 07-09-2012, 11:11 PM   #2107
gday guys,just finishing off a few things on my te v2,somethings a bit out of whack,i cant find anything thats causing it ,looks like ive got moreanti squat on the left than the right,checked all bushes and its all set up as per the default setup rear roll ctr lower front in the middle,same both sides,there be a good 3mm in it,the body mount is running out of whack,its got me stuffed, also whats everyone running with the front upper arm position shows inside on the default setup and the v2 manual says outside.
cheers heaps for the help.
burty.
burty is offline   Reply With Quote
Old 07-12-2012, 05:16 PM   #2108
rip67vdub's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to rip67vdub
Questions?? Looking for Lipo/LiFe pack for 966
Any good suggestions or recommendations? Your help is greatly appreciated. Thanks for looking.
rip67vdub is offline   Reply With Quote
Old 07-13-2012, 01:38 PM   #2109
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The Xceed li-po
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 07-15-2012, 04:09 AM   #2110
Paulie Bee's Avatar
Default Welcome Phil Trotta
I'd like to personally give a warm welcome to Phil, a veteran On-Road racer to the Serpent ranks. Phil recently aquired two 966 TE and did a really nice job building them.
For those who do not know Phil, he is a very knowlegdeable and experienced Nitro as well as Electric racer. Ask him questions on this thread and I know he will answer. We are fortunate to have him aboard.
More importantly, Phil is a gentleman.
Welcome Phil.
Paulie
Thank You...
PT RC Racing Oils
Old 07-15-2012, 04:18 AM   #2111
Paulie Bee's Avatar
Default Xceed Lipo Pack
Dan is right...
Xceed Lipo Pack comes with balancer although the image here does not show it. Awesome battery.
http://www.serpentamerica.com/shop/p...&cat=59&page=1
XCE105001
(1300-7.4V)
$34.40
Thank You...
PT RC Racing Oils
Old 07-15-2012, 06:40 PM   #2112
Hey Paulie como estas! Hope all is well
Old 07-16-2012, 09:29 PM   #2113
Welcome to Serpent Phil
Old 07-17-2012, 02:34 AM   #2114
Thanks Paulie and Dan .... The exceed pack is perfect for the 966 te over other cells ... It's flatter and wider and will not bind on bottom of fuel tank as other cells( LIpo) are fatter and will push up or bind on tank. Causing clearance problems with carb ....
Ran this car first time on sat Car was a good build seems to have a lot of rear bite. I suggest ordering option spring sets front and rear from serpent to dial in to your track kit springs may be a little soft I'll be testing more tomarrow
PHIL TROTTA
Old 07-17-2012, 11:29 AM   #2115
gearhead_22's Avatar
Send a message via AIM to gearhead_22
yeah phil welcome to serpent, so will you be making the trip to bluediamond for the novarossi race?
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
