Old 06-15-2012, 02:10 AM   #2086
M7H
M7H's Avatar
Originally Posted by harrydin View Post
how to adjust my throtlle servo coz it always stuck at the fuel tank...already try 2 engine(o.s speed n novarossi kanggaroo)still the same...im using laydown throttle servo position...need help from the pro asap....thnx..cheers.
-harrydin@MALAYSIA-
With Novarossi, you have to play with rotating the carb, and also rotating the ball link, but it can be done, without modification of anything.....
Serpent
M7H is offline   Reply With Quote
Old 06-15-2012, 04:31 AM   #2087
Registered User
Smile thanx
Thanx everybody for the info, with the true motion the car really jumping...marvelous. ...
harrydin is offline   Reply With Quote
Old 06-15-2012, 07:18 PM   #2088
Wow that top end needle is set a lot further in compared to my Nova engines, what fuel are engine temp are you running ?
peppernick is offline   Reply With Quote
Old 06-16-2012, 10:43 AM   #2089
LOW ET's Avatar
Trader Rating: 94 (100%+)
which body is everyone using on the 966 lately? how does it compare to the zytec?
LOW ET is online now   Reply With Quote
Old 06-16-2012, 01:44 PM   #2090
Registered User
Smile thnx
Iam setting my car watching micheal at you tube how he set the car from part 1-part5,my car handling was good,using nitro x,engine temp is good,just talk to the hand to make the job done....i really like my car now....
Old 06-18-2012, 12:46 AM   #2091
M7H
M7H's Avatar
Don't compare settings...
It's a 3T club stock motor, which reaches almost 7 minutes on a tank of fuel.
Serpent
Old 06-19-2012, 02:47 AM   #2092
gday there guys,been a while,got another 996 recently and was looking for some tips if i could,looking threw the v2 manual just unsure on a few things,all the little orange washers and cones.where are they for,looked at some pics on the serpent website and it shows them under the rear upper wishbones,but in the 966 manual it says 2mm,also is the v2 default setup the same as the te setup other than the shock layout, the front upper arm position looks differnet on the te default setup compared to the v2 manual,it shows outsid ehole but inside on the setup sheet.
sorry for all the dumb questions again,cheers all for your help.
burty.
burty is offline   Reply With Quote
Old 06-25-2012, 10:43 AM   #2093
Paulie Bee's Avatar
Default 966 clearly dominated the field and wins Byron's Cup in Joliet!
WOW Paolo's car was awesome the whole 1 hour. Congratulations.
I wish all the 966TE fanatics like me could have seen this one hour show.
Impressive!
http://www.redrc.net/2012/06/morgant...rld-challenge/
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 06-25-2012, 12:38 PM   #2094
Rick Vessell's Avatar
Impressive!
Good job this weekend keeping up with wrenching and pit duties on all 3 cars Paulie. Get some sleep!
Futaba, O.S. Engines, Trakpower, HB Racing, SpeedPassion USA, Eggroll Inc., Vesselli Racing
Rick Vessell is online now   Reply With Quote
Old 06-29-2012, 11:51 AM   #2095
cho~ke's Avatar
anyone have any experience replacing front universal pins? They seem to be larger in diameter then 3mm.Just wondering if anyones have replaced them and what u guys have used.Hudy pins 3m x 12m just slides in and out
R&D = rebuild & destroy
Jimmy Cho
cho~ke is offline   Reply With Quote
Old 06-29-2012, 04:37 PM   #2096
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i used the Team Titan ones, 3x11.8 , they fitted fine.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-01-2012, 04:34 AM   #2097
Can you post the link about the set up book please??
Originally Posted by djiewie View Post
@HPC
Off power steering or turn in i suppose you mean.
Best not to mount to much forward just for turn in because you will get a nervous car on high speed. Maybe you can try the next;
- front stabi harder,
- front shock harder,
- front spring harder,
- rear droop less, let the rear lift with braking
- front droop more, let the front stick to the asfalt
- front lower rideheight,
- rear higher rideheight,
- front shore less (30),
- rear shore harder (37) in stead of 35,
- rear stabi harder (gets much more steering),
- rear shocks harder(spring, oil, or more vertical)
Try it and see what you like because there are also other effects wich maybe you don`t want. Hope it helps you. You can also
Download setup book from the best brand in the market with the best support
in the world.
Ted Su(TW) is offline   Reply With Quote
Old 07-01-2012, 02:15 PM   #2098
djiewie's Avatar
i can`t quote a other brands setup book,on this thread but browse the serpent site. Its bound to be there somewhere downloadable.
i`ve downloaded the 10th scale from the serpent site before it was the 720 i think.
EDIt http://www.serpent.com/product/903008/downloads/
here you go the 960 setup book from serpent. be quick before the remove it.
djiewie is offline   Reply With Quote
Old 07-01-2012, 09:40 PM   #2099
Thank you!
It's a good read.
Old 07-05-2012, 06:18 PM   #2100
bcebwecb's Avatar
Has anyone tried to put an angle on the upper bracket by adding or removing shims? Can anyone tell me what that would do to the car?
Brandon Cho
1 Corinthians 10:31
_______________________________________________________________________________
Team ARC USA - Hobby Authority Distribution - TiTAN BLITZ - Prolevelrc
bcebwecb is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
