Old 04-20-2012, 06:32 PM   #2071
nitrodude's Avatar
I finished building my new 966 TE V2 this past weekdend, and I have to say that I fell in love with the new shocks They're incredibly easy to bleed, and they all have the same rebound, right from the first time. No air in them either. Just easy!
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-20-2012, 10:08 PM   #2072
Team Kamikaze's Avatar
So you like the _u_e_ shocks huh?
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-21-2012, 01:52 PM   #2073
nitrodude's Avatar
LOL yeah, the shocks are pretty good, makes the car easier to maintain
Steven Muller
Ronin Speed Parts
Old 04-25-2012, 08:59 AM   #2074
HPC
Hi guys,
Would appreciate if anybody could assist me on these 3 questions:
1) How does cutting out the holes on the front bumper affect handling?
2a) Front steering knuckles,can be mounted to give more turn in on corner entry, or more on power steering at corner exit. Which position does what?
2b) On setup sheets,I noticed it is indicated by position 1 or 2. Which position is 1 ? or 2 ?
Your kind assistance is very much appreciated.
Thank U.
HPC is offline   Reply With Quote
Old 05-01-2012, 07:18 AM   #2075
Hi,
1) In process of installing the true motion clutch. Just want to confirm that if using the black shoe with alu clutch bell, i am supposed to screw the clutch spring nut all the way in and back out 1.5 turns. I am thus effectively tightening the clutch spring nut to 2.05mm. Is this correct? so 'tight'?
2) If using the normal clutch bell with brown or red shoes, is there any change to how tight I should tighten the clutch spring nut? With the normal clutch system, I tighten the cllutch spring nut to approximately 1.5mm. With the true motion clutch, do I need to deviate significantly from this?
If anyone can provide answers/clarification to the above, would be most grateful.
sam
sammies is offline   Reply With Quote
Old 05-02-2012, 02:31 AM   #2076
M7H
M7H's Avatar
Sam, I never use callipers to measure how tight I set the clutch. After I am happy with my clutch, I always check who many turns I can fasten the spring completely. This is much easier next time when rebuilding a clutch, just fasten it and "unscrew" for 1.5 turns.
1 turn actually, is equal to around 0.7mm of spring tavel, very usefull to know.
I recommend the first time you run the clutch to set the spring load to 2 turns, until the clutch loosens up (depending on how tight the flyweights go over the pins), you can tighten it if needed. Clutch gap, smaller the the "old" clutch, around 0.4 - 0.5 to begin with.
Serpent
M7H is offline   Reply With Quote
Old 05-02-2012, 12:37 PM   #2077
Please share some v2 pics.....thanks
lynx75 is offline   Reply With Quote
Old 05-09-2012, 04:36 AM   #2078
getpip's Avatar
I have picked myself up a 966Evo to go racing with ...
It looks like I've got plenty of reading to do.
Pics.. Pips new ride!
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 05-20-2012, 06:53 PM   #2079
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Default kevco cup race at bluediamond rc
Serpent dirver Jamie Gonzalez TQs and win with the 966te v2. good run congrats.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 06-12-2012, 06:56 AM   #2080
damn serpent 966 forum is quite
Old 06-12-2012, 09:42 AM   #2081
nitrodude's Avatar
Thats cause the car is is perfect and easy to setup
Steven Muller
Ronin Speed Parts
Old 06-12-2012, 12:19 PM   #2082
M7H
M7H's Avatar
I will ask them to weaken some parts, so we have something to talk about....
Serpent
Old 06-12-2012, 12:26 PM   #2083
nitrodude's Avatar
Yeah, we need gear striping problems or weak front upper arms LOL
Steven Muller
Ronin Speed Parts
Old 06-14-2012, 11:10 PM   #2084
Registered User
Smile need help
what is the best set up spring tension? my serpent 966te(using serpent 966tev2)flywheel,flyweight...my clutchbell is getting hot,i hav to open the spring untill left 1 thread of screw at the spring screw thread.....how to adjust my throtlle servo coz it always stuck at the fuel tank...already try 2 engine(o.s speed n novarossi kanggaroo)still the same...im using laydown throttle servo position...need help from the pro asap....thnx..cheers.
[email protected]
harrydin is offline   Reply With Quote
Old 06-15-2012, 12:02 AM   #2085
Robert R's Avatar
As far as clutch there is YouTube video on the set up, it very helpful. Look it up. As per your throttle I had same issue, I put thicker rubber seal on carb which lifted it up.
Chef Robert
Serpent 977
Serpent 811 GT
I have Byron fuel 16, 20, 25 & 30
Robert R is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
