Old 04-09-2012, 10:51 AM   #2056
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by Team Kamikaze View Post
Yes, every part is available!
I just ordered the quick release c clips that replaces the E clips right. and what is the part numbers for the other parts.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 04-09-2012, 11:06 AM   #2057
Team Kamikaze's Avatar
Originally Posted by gearhead_22 View Post
ran my 966 te yeasterday and the car was good on the first outting of the day before my second run i wanted to change the shift point to shift a little later and when i went to pop off the E clip it would not come off. I had to lossen the left side gear and slide the shaft over. Well after all that I changed the shift point and put the car back out first lap was good and hit the straight on the second lap and off went the E clip, gears, gear spacer and pin. I found everything but the gear spacer and pin, are these parts available yet without buying the whole two speed kit.
When you put the 2 speed back together, make sure you leave a minimum of .5mm of side to side play on the 2 speed shaft.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-09-2012, 12:02 PM   #2058
thanks will do
Old 04-13-2012, 11:29 AM   #2059
Redko's Avatar
Hi Guys,
can i check if anyone tried the 966te chassis by CSO ??
is it better??
--TAMIYA--TRF 419X, TRF 419, TRF 418, TRF 417V5, TRF 201, M-05Ver.2, FF-03R, TRF 101, F104WGP, F103RM, RM01
-- Infinity -- MUGEN -- SANWA -- HOBBYWING -- ProSpec -- ORION -- OS -- Muchmore -- Wild Turbo Fan -- Axon -- MTB
Redko is offline   Reply With Quote
Old 04-13-2012, 12:20 PM   #2060
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Redko View Post
Hi Guys,
is it better??
no its alot softer. i ran , well still run it for my EP car. but when the 966 went to the single screw underneath for the steering post, the CSO chassis in a crash bent the chassis underneath after a mild crash so the steering post was bent backward on an angle. i bent it back straight, then put the older radio tray back on and used the top screw again.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-16-2012, 05:08 AM   #2061
HPC
Hi guys,
From your experience, which body shell wud give the 966 the most Off Power Steering?
HPC is offline   Reply With Quote
Old 04-16-2012, 12:37 PM   #2062
stefan's Avatar
Send a message via AIM to stefan
Originally Posted by HPC View Post
Hi guys,
PF R15B and Blitz R11, of course depending on how far forward you mount them.
stefan is offline   Reply With Quote
Old 04-16-2012, 01:37 PM   #2063
HPC
Dear Stefan,
Thanks for your response. What is the maximum, how far forward that I can mount these 2 shells?
I am presently running the Protoform P909 with 20mm forward. Will be trying 30mm forward next. Wud like to more Off Power Steering, if possible.
Best Regards.
Old 04-16-2012, 06:02 PM   #2064
nitrodude's Avatar
Perhaps you need to change the setup, post it here so we can see of theres any problems with it.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-17-2012, 01:37 AM   #2065
djiewie's Avatar
@HPC
Off power steering or turn in i suppose you mean.
Best not to mount to much forward just for turn in because you will get a nervous car on high speed. Maybe you can try the next;
- front stabi harder,
- front shock harder,
- front spring harder,
- rear droop less, let the rear lift with braking
- front droop more, let the front stick to the asfalt
- front lower rideheight,
- rear higher rideheight,
- front shore less (30),
- rear shore harder (37) in stead of 35,
- rear stabi harder (gets much more steering),
- rear shocks harder(spring, oil, or more vertical)
Try it and see what you like because there are also other effects wich maybe you don`t want. Hope it helps you. You can also
Download setup book from the best brand in the market with the best support
in the world.
djiewie is offline   Reply With Quote
Old 04-17-2012, 03:42 AM   #2066
Michael_T's Avatar
Trader Rating: 47 (100%+)
Send a message via MSN to Michael_T
Massive Serpent 966 Parts sale.
See link below:
Serpent 966 Parts, BNIB, over $575US in Parts
Michael_T is offline   Reply With Quote
Old 04-17-2012, 08:50 AM   #2067
HPC
Originally Posted by djiewie View Post
@HPC
in the world.
Thank U very much for your suggestions. Will give it a try, one at a time.
Best Regards.
Old 04-17-2012, 08:54 AM   #2068
HPC
Thank u for the kind offer of assistance. Will try a few more setup changes before posting.
Best Regards.
Old 04-20-2012, 07:20 AM   #2069
ok folks I have one last problem with my 966TE. on the caster settings in the manual it shows two (4mm) spacers behind the upper arm and a (2mm)+(1mm) spacer in the front of the upper arm, with that done I have a little less than (1mm) of space left is this normal.
Old 04-20-2012, 11:19 AM   #2070
I normally try to fill the gap with another shim, if it's too thick I will sand it down a little so it will not bind the upper arm.
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
