Old 03-28-2012, 02:01 AM   #2041
HPC
Hi,
How does the upper/lower position of the eccenter on the front steering knuckle affect handling?
Would really appreciate if anybody can assist me on this .
Thank You.
HPC is offline   Reply With Quote
Old 03-28-2012, 03:33 AM   #2042
Paulie Bee's Avatar
Default Front Axle Eccenter Effects
Originally Posted by HPC View Post
Hi,
Thank You.
Hello:
In brief this affects front roll-center:
  1. axle down - most steering
    axle in middle- neutral steering
    axle up- least steering (I've hardly ever used)
Try both mid the lower positions at the track back-to-back, and you will see a major difference between down and mid positions
Paulie B
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 03-28-2012, 06:57 AM   #2043
HPC
Hi Paulie,
Thank U for the reply.Much appreciated.
Just to confirm, axle down is, using the top eccenter hole?
Old 03-28-2012, 02:22 PM   #2044
Paulie Bee's Avatar
Hi Paulie,
I think so. Not sure because I dont have the car in front of me but basically, when you are looking at the steering blocks from the side, the axle down means that the axle is below the center of the hole of the steering block. When the axle is in the center, it is the mid/neutral position. These are the two positions I use most. If you flip the eccenter piece then the axle would be in the upper position which we rarely use.
Let me know how it feels after you try it!
Paulie B
Thank You...
PT RC Racing Oils
Old 03-28-2012, 06:55 PM   #2045
HPC
Paulie - Thank U very much !
Old 03-29-2012, 05:06 PM   #2046
hi,
i have a 966TE but just noticed a V2 has come out
what is the difference?
can the parts be purchased seperately to make my original TE a V2?
I cant seem to find info anywherE?
implusepro is offline   Reply With Quote
Old 03-29-2012, 05:55 PM   #2047
nitrodude's Avatar
Originally Posted by implusepro View Post
hi,
Yes, you can buy the parts. The only thing different on the V2 are the new shocks and the new clutch. Everything else is the same as your TE. Im picking up my V2 next saturday, Im running a 966 that I bought new back in 2009, Im NEED new car
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-29-2012, 08:28 PM   #2048
Do you know the part number for the new clutch? Is this it:
http://www.serpent.com/product/903222
So only some minor change (clutchbell, spring, Flywheel are unchanged)
Do you guys think the new shocks are worth the extra $$$
Old 03-29-2012, 08:35 PM   #2049
nitrodude's Avatar
http://www.serpent.com/product/903011
No, thats the old clutch. Look at the link above.
Centax True Motion Clutch
Serpent introduces new Centax clutches for 1/8 onroad.
The development of the Centax clutch continues. Serpentís designer Ron Ton was the innovator of this revolutionary clutch system in the mid 90-ties. Soon it has become the standard in onroad racing, as all other brands adopted similar systems.
Many variations have been tried, but in the end it still comes close to the original idea.In the latest development the tapered shape has been moved from the flywheel to the pressure plate instead, improves punch and reliability.
Serpent continues the use of the hard Centax spring to set preload, as its less critical and faster to adjust.
The 1/8 scale Centax True motion clutch, has the black shoe and aluminum cutch housing as standard. Yellow and red shoes can be tried as well, as well as the steel or light steel clutch housing.
The Centax system, invented by Serpent (Ron Ton) in 1992 is since long a standard in the rc industry.
Steven Muller
Ronin Speed Parts
Old 03-30-2012, 01:49 AM   #2050
hi,
True motion clutch and membrane (bladder) shocks.
CPD Racing
chris_dono is offline   Reply With Quote
Old 04-02-2012, 09:49 AM   #2051
gearhead_22's Avatar
Send a message via AIM to gearhead_22
put some laps in with the 966te yesterday very happy with it. I only had one problem, I strip second gear twice, I think it was because the track was fresh and still had some debris on the track pinion was beatup as well.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 04-09-2012, 04:36 AM   #2052
peter.'s Avatar
Default 966 gear ratio
whats the internal gear Raito from the 966te
and how do you calculate that
greetings peter
peter. is offline   Reply With Quote
Old 04-09-2012, 05:20 AM   #2053
Pattojnr's Avatar
Trader Rating: 19 (100%+)
greetings peter
http://serpent.com/file.php?FileID=4833
try this out. it may be what your after.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-09-2012, 06:31 AM   #2054
ran my 966 te yeasterday and the car was good on the first outting of the day before my second run i wanted to change the shift point to shift a little later and when i went to pop off the E clip it would not come off. I had to lossen the left side gear and slide the shaft over. Well after all that I changed the shift point and put the car back out first lap was good and hit the straight on the second lap and off went the E clip, gears, gear spacer and pin. I found everything but the gear spacer and pin, are these parts available yet without buying the whole two speed kit.
Old 04-09-2012, 09:43 AM   #2055
Team Kamikaze's Avatar
Yes, every part is available!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
