Old 03-08-2012, 06:28 PM   #2026
Paulie Bee's Avatar
Default Blue Diamond Park
Originally Posted by Supafast View Post
thank guys for the help
Hello Supafast:
I guess you guys are running 8th scale at Blue Diamond? Can you please give me all the information on this years plans for track expansion and making it user friendly for the 1/8 guys? Any schedule posted, hotels, etc? Please fill me in. Who is the track administrator and what it their contact information?
I'd love to come back to Blue Diamond and run some races this summer.
Thanks,
Paulie B
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 03-08-2012, 06:36 PM   #2027
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Originally Posted by Paulie Bee View Post
Hello Supafast:
Thanks,
Paulie B
hi paulie you can go to the racing forum and go to bluediamonds page to get all of the info race you soon, glad to get more serpent driver to bluediamond
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 03-09-2012, 01:15 PM   #2028
Paulie Bee's Avatar
Looking forward to seeing all my DE and MD friends again. What awesome memories.
Paulie B
Thank You...
PT RC Racing Oils
Old 03-12-2012, 11:07 AM   #2029
I'm wondering which kind of cars is pointing my choice:
- Serpent 966 TE v2
- Mugen MRX5
I'd like to know pros and cons, an honest and open discussion.
Thanks for your help.
lynx75 is offline   Reply With Quote
Old 03-13-2012, 02:10 AM   #2030
M7H
M7H's Avatar
Hahaha, and what answer do you think you will get?
Serpent
M7H is offline   Reply With Quote
Old 03-13-2012, 02:03 PM   #2031
I hope an honest answer...but I think more focus on the 966
Old 03-13-2012, 02:20 PM   #2032
Both cars you are asking about are good cars, and both can be fast as you can see in my signature i run the 966. I have built several mrx5 for friends and have drove it as well, it has its good and bad like any car does. What i would say to you is see which one is easiest to get parts for.
On another note the newest addition the te and now v2 have a big sweet spot for setups, i have a base setup i use for me that has been a good starting point for any surface i have run it on. I think the serpent is the most durable car i have raced with and that is a big part of racing.
You will not be disappointed with a Serpent 966!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 03-15-2012, 02:04 PM   #2033
Thank you for the feeback, appreciate. I'll let you know my next choice.
Old 03-16-2012, 02:29 AM   #2034
Default 966 TE
Hi there,
Can anyone explain what's the effect that we notice on the track, having 1, 2 or 4mm shims under the front suspension bracket?
zeca is offline   Reply With Quote
Old 03-16-2012, 05:44 AM   #2035
Super Mario's Avatar
Default Centax True Motion Clutch
Originally Posted by Team Kamikaze View Post
The best Aluminum Clutch bell (903387) set up is with 6587XP Black shoe, 909520 clutch spring and 903199 leading flyweights.
I am looking to get my clutch set up right as its on of the main things that will make you fast, if you have it right. So far, I have not had it working well..
Since the release of the Serpent Centax True Motion Clutch. Is this now the better way to go for the best clutch? Or is the above set up, still the way to go??
Thank you,
Super Mario
RRR Raceway
Let the fun begin!
Super Mario is offline   Reply With Quote
Old 03-16-2012, 06:21 AM   #2036
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Thank you,
the Bell and shoe are still the same. flywheel shoe holder and Flyweights are different. so you can still use that Alloy bell and Black shoe setup for the true motion clutch. but the alloy bell and black shoe is definately the best clutch i have had, cant wait to try it with the updated flywheel bits.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-17-2012, 03:53 AM   #2037
Paulie Bee's Avatar
Default Front Roll Center Upper pin positioning
Originally Posted by zeca View Post
Hi there,
Hello Zeca:
Obrigado for the Good Question!
I’m glad you asked because it helps refresh my memory too.
This is copied in part from a leading set-up company's set-up book: This is how I understood it the first time. I'm not sure if it the best explination but it helped me to get a basic understanding. I suggest testing and trying for yourself.
Good luck...Paulie B
I am assuming you are placing equal amounts of shims under the bracket, front and rear holes, bracket and pin obviously stays flat as you go up or down:
EFFECTS OF FRONT ROLL CENTER ADJUSTMENT
In General, Front roll center has most effect on on-throttle steering during mid-corner and corner exit.
Front roll center Effect
Lower the RC---You are raising the pin More Shims under the bracket:
• More on-throttle steering.
• Car is less responsive.
• More weight transfer at front of car.
• Better on smooth, high grip tracks with long fast corners.
Raising (Higher) the RC---You are lowering the pin Less Shims under the bracket:
• Less on-throttle steering.
• Car is more responsive.
• Less weight transfer at front of car.
• Use in high grip conditions to avoid traction rolling.
• Use on tracks with quick direction changes (chicanes).
Don't forget to re-check your set-up after changing the RC each time.
Thank You...
PT RC Racing Oils
Last edited by Paulie Bee; 03-17-2012 at 04:18 AM. Reason: spelling was not my specialty:)))
Old 03-17-2012, 06:27 PM   #2038
Supafast's Avatar
what r the best 2 speed gears to run on the 966
Shepherd velox 10
Airtronics MT4 Spektrum 6040
SUPAFAST SAYZ GO BIG OR GO HOME!!!
www.SkyrocketRacing.com www.GForceHobbies.com
Supafast is offline   Reply With Quote
Old 03-17-2012, 07:45 PM   #2039
Paulie Bee's Avatar
Default Gearing
I'm not confirming that this is the "best" as you are requesting though this is dependant on the track size, motor/header/pipe combo, tire size, traction, etc, etc, etc, but generally you can start with 15/48, 19/45 then test and adjust.
Note:
After trying this gear ratio, consider swapping the spur gear sizes first before changing-out the 15/19.
Thank You...
PT RC Racing Oils
Old 03-19-2012, 06:13 AM   #2040
Hello Zeca:
Hi Paulie B,
Thanks a lot for your help
Abrašo, thanks
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
