Old 11-07-2011, 12:18 PM   #1951
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
Originally Posted by rcfan48 View Post
Are serpents any good? Im thinking about buying one.
I love mine .....the car is on point ..can't wait to upgrade mine to the TE
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 11-09-2011, 04:10 PM   #1952
2CARTEAM's Avatar
Get one and you'll never look back. A great car with excellent parts support.Out on the west coast you have Kamikaze toys and hobbies with great parts and techniocal support.
Strong, durable and cost effective to run. We've had ours for 3 yrs and just recently upgraded it to the TE. LOVE thiscar!!!!
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 11-12-2011, 06:47 PM   #1953
Default New 966
Hey guys,
Just finished our build of the 966TE, WOW what a sweet piece of engineering this baby is. Easy build, almost no hassles and NO missing parts
Have a few minor questions on set-up though.
What seems to be the preferences on the following ...
Where do most guys run the Front Top Arm? IN or OUT,
Also the shims under Front Top Arm?
I remember a set-up on here somewhere suggesting running different thickness shims front and back? (Almost like Anti dive, but on the Upper Arm)
Also Rear Lower Roll Center; Top, Botttom or Anti Squat?
Thanks in advance for your suggestions,
Looking foward to getting this baby on the track and getting it Dialled...
Warren Maker is offline   Reply With Quote
Old 11-12-2011, 07:09 PM   #1954
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Warren Maker View Post
Hey guys,
Hi Warren, i see you Failed to keep the kit away from Ryan ? haha.
on setup, seemed rear middle insert for lower roll center was a good start. as far as front arms, i used inner position, and ran it as per the build to start with, and to be honest, i didnt have reason to change it . the car had ample steering and rear grip was great. id highly suggest the front alloy swaybar holder set 903359 , will have hassle free racing after that. Hope Ryan likes the car, im sure he will do well with it, but its almost a shame to put it on track, they look amazing ! haha
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-12-2011, 07:34 PM   #1955
[QUOTE=Pattojnr;9902653]Hi Warren, i see you Failed to keep the kit away from Ryan ? haha.
YEAH... Didn't stand a chance
Thanks for the tips, actually I think it may have been you Paul that mentioned a set-up change regarding the front Upper Arm shims.. Something about a thicker shim at the rear?????
We have the Alloy front sway bar holder already.. and have also fitted the SOFT front swaybar.
Also I notice the old car had the Blade Style REAR roll bar, but has now changed to the wire style. Any reason for this. We have found in the past that the Blade style seemed to work a little better on bumpy tracks at least. Can the Blade style still be fitted to the TE chassis ?
Thanks again.
Old 11-12-2011, 08:11 PM   #1956
Default 966 Body
Also, can anyone give me a measurement please from front of Plastic Bumper to shell thanks. Will mount the shell next week. I take it the Protoform P909 is the shell of choice at the moment. Ryan likes a ton of steering
Old 11-12-2011, 08:21 PM   #1957
Pattojnr's Avatar
[QUOTE=Warren Maker;9902742]
Thanks again.
with the old car i ran 1mm angled top front arm. i havent had a reason to do so yet on the TE. i have found that the wire bar setup is more consistant. the rear blade type i have had a few incidents bend the blade, enough to tweak the hole thing. so for me i will stick to the wire type. cant help with the P909, i run the blitz bodies, R11 or R09.
Serpent - Walter RC
Old 11-13-2011, 01:51 AM   #1958
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Hey guys,
Warren, I think me and Ric is running 2mm fr and 1mm rr on the top bracket. I have try anti-squat at Lilydale but didnt like it.
if Ryan like tons of steering then PF15B is what he need, I mount my 909 15mm from the bumper which I found is understeer a bit so next time I will try 20mm
tl2111 is offline   Reply With Quote
Old 11-13-2011, 02:23 PM   #1959
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
20mm for the 909. The R15 and R11 have the dimples for mounting of the 966. Enjoy
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-13-2011, 09:10 PM   #1960
Default Front WOS Knuckles
Thanks for the heads up on the shells guys.
We have also fitted the front Wide Off-set steering Knuckles.
Going on past experiences this should increase over-all steering Have you guys found the same with this car... ??also with these steering knuckles what is every-one running the front track width at and are you shimming the same as kit ?
Thanks again.
Old 11-28-2011, 03:55 AM   #1961
Default Anti-roll bar-set front alu 960/966
Hey guys I'm just wondering if anyone out there knows of anyone that has a Serpent Anti-roll bar-set front alu 960/966 #903359 in stock at the moment? Im in Australia so I might need a shop that ships international. If anyone could help that would be ace!
Cheers, Mick
micksquires is offline   Reply With Quote
Old 11-28-2011, 06:30 AM   #1962
Cheers, Mick
Have you try walterrchobby? I bought a set last week, give them a call and ask for Jay.
kickertrf is offline   Reply With Quote
Old 11-28-2011, 07:19 AM   #1963
Trader Rating: 58 (100%+)
Cheers, Mick
try rcgoods.com from Hong Kong, so it's should ships to you in no time.
Skaidragon is offline   Reply With Quote
Old 11-28-2011, 03:31 PM   #1964
Thanks so much, they had one left!
Old 11-28-2011, 03:55 PM   #1965
gearhead_22's Avatar
Send a message via AIM to gearhead_22
i have the 966 evo and up graded to the team ed. shaft and two speed, why dont they sell the damn bearing you need to do the switch or at least tell you that you need them
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
