Old 09-16-2011, 04:44 PM   #1921
tomdex's Avatar
Trader Rating: 4 (83%+)
Default Bearing Eccenter Part # Clarification
Hi Guys.
After racing my 966 last weekend, I must've been 'kissing' too many track pipes with the front wheels and have damaged 3 out of 4 front bearing eccenters (the ones that insert into the Steering Block #903233).
From the manual, i'm seeing that the replacement item is part #909396, but the Serpent website does not call these up for that application??
http://www.serpent.com/product/909396/
Is there an ally upgrade for this part, as it seems to be a weak point?? I lost a front wheel/axle assembly during the main due to this part failing.
I see there is part #903160 ally bearing eccenter, but I beleive this is an upgrade for part #903118 (the bearing eccenters for the front one-way axle).
The one-way runs a larger OD bearing #1347 (12 x 21) rather than the wheel bearings #1346 (12 x 18).
Can anyone clarify what the ID of the ally bearing eccenters are please??
Thanks in advance. Tom
tomdex is offline   Reply With Quote
Old 09-16-2011, 04:53 PM   #1922
dbl
dbl's Avatar
Originally Posted by tomdex View Post
Hi Guys.
Check the link below. They might have it in stock.
http://kamikazercracing.com/proddetail.php?prod=SER9660
I have these in my 966 and they fit perfectly.
dbl is offline   Reply With Quote
Old 09-16-2011, 06:47 PM   #1923
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
They work great!!!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 09-17-2011, 09:48 AM   #1924
Team Kamikaze's Avatar
Hi Guys.
Yes, the Aluminum wheel hub eccentrics is in stock!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-17-2011, 04:54 PM   #1925
firecat's Avatar
bought a set of these for my 966 very nice fit and finish top notch 100% these are a must if u have close encounters with boards they come in a set of 4
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 09-20-2011, 08:19 PM   #1926
vones's Avatar
Unhappy
Originally Posted by vones View Post
Anybody had the experience of the 3 screws becomes loose after a couple of runs for the new 2 speed housing of the TE edition. It caused my 2nd gear to strip. From what I observed, the screws becomes loose first, after that it un-loosened out of the spur making the holes of the 2nd speed housing elongated. It was downhill from there. Is it the material? or is the screw length not long enough? Stock is M3x5mm. The recommended shims are in place as per manual. Gearing used is 16/20, 49/45. The design could be further improve with the inclusion of locating studs(similar to the design of the mugen spurs) on the spurs itself given that the gear housing already have 6 holes. Could someone share their experience?
You guys with the new transmission system got no such problem as described?
vones is offline   Reply With Quote
Old 09-23-2011, 10:43 AM   #1927
GREGORY!'s Avatar
Does anyone have a set up for low traction and cold weather?
please?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 09-26-2011, 03:07 AM   #1928
Doug M's Avatar
Congratulations to Paolo Morganti for TQ'ing and then winning the 1/8 USA ROAR Nationals with his 966TE! It must feel good to be National Champion!
Congratulations to Joaquin De Soto for winning the 1/8 MASTERS USA ROAR Nationals with his 966TE. great job Joaquin!!!!
Doug M is offline   Reply With Quote
Old 09-26-2011, 06:40 AM   #1929
xtremes's Avatar
That was a well deserved win for Paolo.......Congratulations !!!
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Old 09-27-2011, 12:37 PM   #1930
In celebration for being the 2011 US 1/8 National Champion, the price for the 966 will be on sale for only $599.99, offer good while supplies last!
http://kamikazercracing.com/proddeta...?prod=903010TE
Congratulations to Paolo Morganti for his TQ and win!!!
Old 09-28-2011, 06:42 AM   #1931
Aza088's Avatar
I hate to say it but i have had the same problem with the 733 TE gear box the 3 screws came loose after 1x race meeting and during the 2nd race meeting i stripped 2nd gear then after close inspection the holes were elongated. replaced the spur and stripped after not even 2 min on the track so i changed the 2nd spur gear holder and hope this fixes this issue. But by reading this thread 1x other person and myself are the only one who has had this problem so i hope its just a freak mistake on our behalf
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 10-01-2011, 08:15 PM   #1932
Can someone post the instuctions for the new rear axle assembly. Serpent site only has half the "team edition" instuctions up
moth898 is offline   Reply With Quote
Old 10-17-2011, 09:06 AM   #1933
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Jamie Gonzalez serpent 966 take TQ at bluediamond skyrocket inv. this weekend.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 10-17-2011, 09:28 PM   #1934
Default SL8 gear box vs SL6 gear box.
Currently I am running my 966 evo with SL6 gear box.
Is it worth to upgrade the SL6 gear box to SL8 gear?
What is the major advantage of SL8 againist SL6 gear box??
pls advise.
Thanks.
R003 is offline   Reply With Quote
Old 10-18-2011, 05:34 AM   #1935
lil-bump's Avatar
Trader Rating: 83 (100%+)
pls advise.
Thanks.
The SL6 is used on the 733 200mm sedan
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
