Old 08-08-2011, 10:27 AM   #1891
RC MARKET's Avatar
Team Kit Released !
RC MARKET is offline   Reply With Quote
Old 08-10-2011, 10:21 AM   #1892
RC MARKET's Avatar
New Fuel Tank
Old 08-10-2011, 10:34 AM   #1893
VexVegaz's Avatar
Originally Posted by Paolo M View Post
I'm trying to figure out how to post it since the PDF file is larger than RCTECH maximum Kb
upload it to a filesharing site like megaupload.com and post the link here.
VexVegaz is offline   Reply With Quote
Old 08-16-2011, 06:11 AM   #1894
NikoRacing's Avatar
Default 966 TE SL8
Hello!
I'm building my new 966 TE and noticed that the 1st spur gear (48t) is not perfectly flat. When I rotate the 8mm shaft the I can see the spur going a little side to side...
The drive flange seems to be ok. Anyone has suggestion or a way to solve the problem?
Thx
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 08-16-2011, 06:53 AM   #1895
Originally Posted by NikoRacing View Post
Hello!
Thx
Experiment with how tight each of the 3 screws are that connect the gear to the drive flange? Just a thought
sammies is offline   Reply With Quote
Old 08-16-2011, 07:19 AM   #1896
NikoRacing's Avatar
mm...sorry I have to correct myself... I have re-checked the drive flange and... the one way bearing seems to be a little bent in the house
Will be hard to make it lined with the flange but I try.
Meanwhile I will ask for a new one
Old 08-16-2011, 07:32 AM   #1897
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the nature of the bearing, it will always have some float. under load and RPM it will finds it seat. but it will rock on teh shaft a little. i doubt its much to worry about. the shaft is bigger, so the bearing is also bigger. the rollers inside need some float to operate. if its a little, that should be fine. if it is lots, and a real bad wobble, then may look at getting another one and seeing if its the same or not. wont hurt to have a spare if it turns out the same.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-20-2011, 06:03 AM   #1898
NikoRacing's Avatar
Originally Posted by Team Kamikaze View Post
The WC parts are original Serpent!
And for all you guys having the carb rubbing the tray or fuel tank issue, Ronin products is coming out with a product that will solve all problems!
Yes it will be made by Ronin
I was looking for some infos here and there on the 966 thread and found this post...
so... the "magic piece" has come??
thx
Old 08-20-2011, 02:38 PM   #1899
rias5037's Avatar
Originally Posted by CharlieJunkins View Post
If, you must try this then it is easy to convert your one way. Grind a flat on the outdrives and then JB weld them in to your one way.
tried out the car today guys, and guess what, it works (for me that is), car was very stable all round (well im sure that it being a full time 4wd made that happen), a bit off understeer but nothing a pair of softer fronts wont solve, finally able to drive this like my 733, a big thank u to guys that made this happen for me.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 08-28-2011, 05:07 AM   #1900
bullygod's Avatar
Default Alu Clutch Bell Setup
Rick is correct. The black shoe with the alu bell is the best clutch in my opinion. If you are running the steel bell, then the yellow pad is the best option, since the black will slip too much.
I run the black shoe with the 909520 serpent spring, 0.9 preload and 0.7 gap
Paolo
Hello Paolo, can you advise on the type of fly weights used for alu bell setup? Are you using leading or lagging on the fly weights? Or you are using the std ones that came with the kit. Thanks.
bullygod is offline   Reply With Quote
Old 08-28-2011, 12:59 PM   #1901
HKC
thx
No sorry, Fingers aren't in the box....
HKC is offline   Reply With Quote
Old 08-29-2011, 04:34 AM   #1902
NikoRacing's Avatar
Haha
..but I was talking about the piece that had to come to solve the problems ont he tank and Nova carburators
Old 08-30-2011, 01:07 PM   #1903
PNT2000's Avatar
nice.....
PNT2000 is offline   Reply With Quote
Old 08-30-2011, 08:58 PM   #1904
Team Kamikaze's Avatar
The best Aluminum Clutch bell (903387) set up is with 6587XP Black shoe, 909520 clutch spring and 903199 leading flyweights.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-31-2011, 07:28 AM   #1905
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Once again Paolo showed how fast he is with his 966 at the GLC. He had a slight mistake on entry to the back straight when he caught Paul. That gave Paul some breathing room for a bout 45 seconds. Then Paolo kicked it up and was right on his tail. Bit the clock expired. Just one more lap!!! Either way great driving by a great driver Paolo. And a great car we have in our stable.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
