Old 08-03-2011, 07:37 AM   #1876
Originally Posted by sammies View Post
Hi Pattojnr,
When putting the front end together, I believe the 'amount' of caster clips on each side of the top arms is 4 + 4 + 2 + 1... 11mm worth of clips. i find i have approximately 1 mm of play for the top arms (i.e. able to move them forward and back). Is this normal? Do you find this on your kit as well?
adding an additional 1mm caster clip will cause binding. unless of course I sand the clips down.
But just want clarification as to whether the free-play with 11mm of caster clips is normal.
thanks in advance.
sam
Originally Posted by Pattojnr View Post
Cheers Sam .
Sammies, i put in the Xtra 1mm clip. it is tight, but not bad. it will free up nicley after a run .
also, last thing i did last night before packing up, the rear axles, i put in the axles, bearings, and the tapered spacer, couldnt get the pin in. so i used some other shims i had. it basically locked up the bearings in the hub ? different shims are fine. i like a little ply in my axles spacing. just a tiny bit.
I pay alot of attention on the play of the arms. I spend a lot of time make them free but no play. I use shims to compensate that play. You can find different manufacturers that sell 3mm shims with 0.1, 0.2 and 0.3 thickness.
Regarding the rear axle, i have asked many time the factory to modify the manual cause that conical shim (1mm) does not fit there. I use 2 x 903235 which is a total of around 0.6mm of spacers
Hope this helps
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 08-03-2011, 08:23 AM   #1877
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Cheers Paolo for the info.
i am nearly done. my hands are sore from wrenching at night, then at work all day. haha is it me, or has the plastics got a little harder ? also a question, with all the flex options on the TE, are many of the guys who have run the car, using the Floating radio tray option ? Thanks.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-03-2011, 09:12 AM   #1878
Yep, plastic is hard. We use power drill!!!!
I run the floating option always
Old 08-03-2011, 10:27 AM   #1879
Hi Paolo,
Could you post your set up from the Timezone race you won?
That would be great for us looking to get the 966 TE.
Thanks.
Kendall is offline   Reply With Quote
Old 08-03-2011, 09:45 PM   #1880
Boa
Have any of you guys compared the 966 to the 966e? If so can you share your knowledge?
Boa is offline   Reply With Quote
Old 08-04-2011, 01:15 PM   #1881
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Look here for more info about the 966E.
http://www.rctech.net/forum/electric...nroad-car.html.
Search the thread to find posts on the Serpent electric.
YR4Dude is offline   Reply With Quote
Old 08-04-2011, 01:52 PM   #1882
YR4Dude's Avatar
New 966 Team Edition radio plate.
Old 08-04-2011, 03:50 PM   #1883
GREGORY!'s Avatar
Paolo and anyone that can answer this.
what is the bigger improvement that can someone make to the old 966 car?the front arms and the rear shock mounts?or something else?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 08-04-2011, 04:26 PM   #1884
Team Kamikaze's Avatar
Front suspension 2011 set (903380),
Rear suspension 2011 set (903384)
Rear Arm/Shock extension set (903377)
This above 3 items will give you significant improvement on your 966
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-05-2011, 12:02 AM   #1885
Hi,
For those who are putting together their TEs... did u have to grind down the brake bushings(the tubes that the springs go over) in order to have the right bearing block to sit properly?
My outter brake pad is now hitting the FR suspension bracket thus preventing the right bearing block to sit properly.
sammies is offline   Reply With Quote
Old 08-05-2011, 03:13 AM   #1886
Pattojnr's Avatar
Hi,
i have clearance on mine.
if it is hitting, i would be making sure your pad on the bearing side is sitting in the tube properly, if you have tightened it and the busing is clamping the pad plate, then it will make the bushing sit out further. just a thaught.
Serpent - Walter RC
Old 08-05-2011, 09:19 AM   #1887
Originally Posted by Kendall View Post
Hi Paolo,
Thanks.
I'm trying to figure out how to post it since the PDF file is larger than RCTECH maximum Kb
Old 08-05-2011, 09:20 AM   #1888
Sam it's correct. The handling of the car improves a lot making it super easy to drive and with a wider sweet spot
Old 08-05-2011, 12:12 PM   #1889
YR4Dude's Avatar
I've stated this before. Those improvements dropped a whole second or more off my lap time. Big difference.
Old 08-08-2011, 09:27 AM   #1890
Hi Paolo,
Ok cool. Interested to see how you set your 966 TE.
Thanks.
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
