Old 07-27-2011, 08:38 PM   #1861
Team STPN's Avatar
Originally Posted by Rich Browne View Post
Great Job Paolo! You and your car were smooth as butter. TQ and a win on a very difficult circuit - well done.
Paolo, you are a class act and a terrific RC racing ambassador. Always ready with a smile and a kind word. For any racer out there - Paolo is quite approachable and VERY knowledgeable I always enjoy technical exchanges with him.
Once again, very well done!!
All I can say Paulo is a class act. Just meeting him at TZR and pitting under the same tent was an honor!! He surely has a wealth of knowledge and not afraid to share!
I don't care what Scotty Barnes says about you Rich you are a classy dude too
Team STPN is offline   Reply With Quote
Old 07-28-2011, 06:18 AM   #1862
Originally Posted by Team STPN View Post
.....Rich you are a classy dude too
Yep, I'm the classiest guy at the Trailer Park. Long live "My name is Earl"!!
Rich Browne is offline   Reply With Quote
Old 08-01-2011, 05:59 AM   #1863
Originally Posted by Paolo M View Post
Rick is correct. The black shoe with the alu bell is the best clutch in my opinion. If you are running the steel bell, then the yellow pad is the best option, since the black will slip too much.
I run the black shoe with the 909520 serpent spring, 0.9 preload and 0.7 gap
Paolo
Thanks for the info Paolo
I actually had some very good results using the black XP shoe with the steel housing. I run on a medium traction complex circit and with a gap of .55 the clutch performed well with very little wear.
JIM1 is offline   Reply With Quote
Old 08-02-2011, 02:45 AM   #1864
Default new to s966.
Hi All,
I just check my 966 carefully.........
I found that the drive train isnt smooth.
1)
the front oneway has movement of about 1~2mm side to side
Do i need to add shims to fix it?
2) the sterring part "servo saver" is slightly touching the the front belt.
is it expected?
3) Both front and rear belt are set to default position. it seems very tight.
And I found a few point the will slightly enlongate the belt. it make the drive train doesnt smooth..
Do i need to use move the pole to "loose" position?
Thanks,
Ray
hpiray is offline   Reply With Quote
Old 08-02-2011, 04:59 AM   #1865
Default SL8 ONE-WAY BEARING
Hi,
With the original 2-speed, I had problems with my one-way and what solved it was the use of diff lube instead of 1-way bearing oil.
For the new SL8 2-speed set, what are you guys lubing the one-way with?
Sam
sammies is offline   Reply With Quote
Old 08-02-2011, 05:18 AM   #1866
Originally Posted by hpiray View Post
Hi All,
1)
is it expected?
Thanks,
Ray
Hi Ray
1) That movement is neccessary to have a free drive train. Do not shim
2) You need to loose the 16t pulley and move it a little bit more toward the exhaust. This will clear your servo saver
3)If you are using the belt included in the kit, i will recommend the softest setting in the front and middle in the rear. After you run it the first time they will be free. For best result in term of free car, use the rubber belts
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 08-02-2011, 05:19 AM   #1867
Originally Posted by sammies View Post
Hi,
Sam
im using one way oil
Old 08-02-2011, 07:30 AM   #1868
Victor Vector's Avatar
And some bloody Hooligan too !!
Jacko
Jack Balchin.
Timezone Hooligan
IBEW Local 48-retired (Definitely, great pension.)
Victor Vector is offline   Reply With Quote
Old 08-02-2011, 11:04 AM   #1869
Hi Ray
Thanks Paolo.
Really solved my problem.
you are real expert!!!
can't wait to test my car!
Old 08-02-2011, 09:11 PM   #1870
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Default 966 TE
hi guys, building my TE kit, anyone know what rear hubs are in the kit ? like std ones or the wide off set ? kit is going together pretty nice, just notice some things are quite a tight fit. cheers.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-02-2011, 11:10 PM   #1871
Team Kamikaze's Avatar
The Rear Uprights that came with the kit are standard offset, as the wide offset rear uprights will have a "W2" stamped on the upright itself. hope this helps!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-02-2011, 11:29 PM   #1872
Hi Pattojnr,
When putting the front end together, I believe the 'amount' of caster clips on each side of the top arms is 4 + 4 + 2 + 1... 11mm worth of clips. i find i have approximately 1 mm of play for the top arms (i.e. able to move them forward and back). Is this normal? Do you find this on your kit as well?
adding an additional 1mm caster clip will cause binding. unless of course I sand the clips down.
But just want clarification as to whether the free-play with 11mm of caster clips is normal.
thanks in advance.
sam
Old 08-02-2011, 11:33 PM   #1873
Thanks Paolo for sharing. appreciate it.
Old 08-02-2011, 11:53 PM   #1874
Pattojnr's Avatar
Cheers Sam .
Sammies, i put in the Xtra 1mm clip. it is tight, but not bad. it will free up nicley after a run .
also, last thing i did last night before packing up, the rear axles, i put in the axles, bearings, and the tapered spacer, couldnt get the pin in. so i used some other shims i had. it basically locked up the bearings in the hub ? different shims are fine. i like a little ply in my axles spacing. just a tiny bit.
Serpent - Walter RC
Old 08-03-2011, 07:14 AM   #1875
Noted. Thanks again Pattojnr
Cheers Sam .
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
