Old 07-10-2011, 07:50 AM   #1771
rias5037's Avatar
Haha, i almost did today, i prefer all four wheels to brake, is there no front spool available for the car instead of the one way? Thing is i cant drive the car with drag brakes and manual braking before the turn after a long straight just isnt doing it for me with just the rears braking.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 07-10-2011, 08:15 AM   #1772
Pattojnr's Avatar
Trader Rating: 19 (100%+)
you will never get the car to turn with front solid, rear solid. you will do more harm in the way of belts, tyres, engines. id say learn to use the brakes. i dont use drag brake, only at full braking, it only slows the car down, not locking up rears if you get what i say
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-10-2011, 02:57 PM   #1773
Hi, what are the bearing sizes used on the new sl8 2-speed shaft?
JIM1 is offline   Reply With Quote
Old 07-10-2011, 04:42 PM   #1774
8mm x 14 mm x 4mm Avid has a nice one with a seal on one side.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-11-2011, 03:55 AM   #1775
Winner's Circle's Avatar
Originally Posted by M7H View Post
"locking" them into position with fueltube, can also help preventing them to bend in case of a hard crash.
It doesn't prevent loosing them though.
That's where cvd's come into play.
Mugen rear dog bones are longer than Serpent. I found that running the Mugen dogbone completely stopped the problem with lost dog bones.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 07-11-2011, 04:09 AM   #1776
M7H
M7H's Avatar
Lee
Yep, but I had 2 Mugen dogbones twisted after only 2 race days. The Serpent ones I have are longer lasting, actually they are lifetime lasting, you only need to replace the pins of course... Maybe things are changed in the meantime, I don't know.
Serpent
M7H is offline   Reply With Quote
Old 07-11-2011, 04:18 AM   #1777
Roelof's Avatar
Send a message via ICQ to Roelof
You will be amazed how long you can run those Mugen twisted dogbones.
But there are different productions, later versions are much better.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 07-11-2011, 11:05 AM   #1778
I agree! Mine were twisted too but they did not break and lasted years.
Lee
Lee Muse
Old 07-11-2011, 11:53 AM   #1779
So, I have fitted all the 2011 updates to my car and am now waiting for the weekend to come so I can try them. I hope the car drives as well as it looks!
I have only one complaint though -
Why do the front shock adjusters hit the upper arm supports? You would have thought that Salven and his team would have spotted this before production........no?
I know this has been discussed previously on this thread but even when I secure a 1mm spacer behind the upper shock mount it still touches.
I checked out Salvens video clip from the worlds and noticed that he was running no lower than 3mm spacers under the upper supports to give a much lower roll centre (to low or not?). This combined with a 2mm spacer behind the upper shock mount seems to cure the problem.
You guys must have come across this problem........? What did you do?
And you don't even get extra shims in the update kit to space the upper shock mount out.......bah!
Old 07-11-2011, 12:58 PM   #1780
nitrodude's Avatar
I grabed a blown out trust bearing and used it as spacers between the shocktower and the bulkhead, problem solved
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-11-2011, 01:17 PM   #1781
Roelof's Avatar
At any hardware store you can get M3 rings for just a dollar/euro per bag of 20 pieces and a normal person in this hobby must have them in his box..
Old 07-11-2011, 02:57 PM   #1782
I have plenty thank-you.
The point I'm trying to put accross is that the 1mm washer on the shock tower just isn't enough especially if the front wheel base is shortened. Obviously a 2mm washer would work but would it compromise the shock operation leaning the top further forward?
Old 07-11-2011, 03:31 PM   #1783
Lilja's Avatar
I think you can safely but 2-3 mm behind the shocktower without messing up the geometry. If you look closely on the car from the side you can see that even with the 1 mm shim that I have now the shock is still leaning slightly backwards towards the top.
Depends alittle on your ride hight aswell but I think youll need atleast 3 mm for it to clear the collar completely.
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 07-13-2011, 10:37 AM   #1784
rias5037's Avatar
Ok guys, after much deliberation ive decided on trying out a locked/solid axle for the front, thing is no one makes this and my machining/mechanical skills is ZERO. So my appeal to you guys is if any of you out there can make one up for me i will pay top $ for your help, please pm me if any of you guys are keen to take up this challenge for me.
Old 07-13-2011, 11:13 AM   #1785
Lilja's Avatar
I think the bigger challenge will be actualy driving the car around the track after something like that
Futaba 4PK
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
