Old 07-05-2011, 10:51 AM   #1756
nitrodude's Avatar
http://www.serpent.com/product/903391/
Interesting...
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-05-2011, 12:28 PM   #1757
Lilja's Avatar
Assembling the new SL8 gearbox atm and Im having a question about the two shims that are supplied and where theyre supposed to go.
Cause the thing is, the bearing on the brakemounting thing wont go all the way out, as it does on the old gearbox. So are those shims supposed to go on the bearings on the outside, or on the inside of the plastic?
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 07-05-2011, 02:44 PM   #1758
The bearing adapter and bearing do sit inboard - no worries use one or two shims as necessary to achieve gear alignment between the bearing and the drive pin/shift hub.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-05-2011, 03:29 PM   #1759
Lilja's Avatar
Yea I was fiddling with it for a while. Turns out I cant use any shims at all because if I do the outer gear on the 2 speed wont turn freely. Suppose you can get the bearing further in if you grind even more on the brakeshaft but it works like this aswell so why fiddle.
Anyways. Got another question as Ive been installing the new rear end aswell. I downloaded the instructions via Serpents webpage, but if I set it up like on the webpage, with all the shims under the upper arms, I cant mount the bodymount in the original setting because the bodymount will hit the outer links on the upper arms. So Im not sure what setup you guys are using or if modification is necessary.
Also using this setup the driveshafts are very close to popping out, so it just feels strange.
Im sorry for all the questions but Im sort of new to Serpent in onroad and I havent driven onroad at all for several years
EDIT: was looking through setups of other people and it seems like the way to go is to mount the bodymount as far up as is possible. Still dont like how the driveshafts are sitting though, they are on the edge of popping out and if I run less droop I can pull them out with my fingers.
Futaba 4PK
Old 07-05-2011, 07:45 PM   #1760
Team Kamikaze's Avatar
What is the measurement of the rear track width? just wondering why your dogbones are sitting on the edge, you might have set it too wide.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-06-2011, 01:06 AM   #1761
M7H
M7H's Avatar
Do they have a lot of play?
I always put some fuel tube in both the wheel axles and drive axle, to give the drive shafts less room to move.
Serpent
M7H is offline   Reply With Quote
Old 07-06-2011, 02:24 AM   #1762
Lilja's Avatar
The gap between the A-arms and the hubs is around 5-5,5 mm as per instructions in the manual.
But yea think Im gonna put some fueltubing on both sides so they cant move around too much.
Futaba 4PK
Old 07-06-2011, 02:45 AM   #1763
M7H
M7H's Avatar
"locking" them into position with fueltube, can also help preventing them to bend in case of a hard crash.
It doesn't prevent loosing them though.
That's where cvd's come into play.
Serpent
Old 07-06-2011, 02:55 AM   #1764
Lilja's Avatar
Yea I did that just now and it turned out great!
So yea pretty much got the car together without any issues. Now I need to find a good base setup and I need to get a new engine as the old one I have barely has any compression left.
Futaba 4PK
Old 07-07-2011, 03:27 PM   #1765
Ok, so I've been running with my front uprights 1 left and 2 right. Gonna try running 1 on the right. What difference should I notice and should I have the bearing blocks facing the rear?
Thanks.
JIM1 is offline   Reply With Quote
Old 07-08-2011, 10:08 AM   #1766
RC MARKET's Avatar
Releasd New 2-Speed Set !
RC MARKET is offline   Reply With Quote
Old 07-10-2011, 05:24 AM   #1767
rias5037's Avatar
Does anyone know if theres anything out there than give the 966 4wd braking, i tried my 966 today and cant seem to get comfortable with just the rears braking, on my 733 i dont use drag break at all, i just manual break and this suits my driving style, i want the 966 to have 4wd braking just like the 733, is that even possible?
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 07-10-2011, 06:40 AM   #1768
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
It is possible but I think it is illegal to do that in 1/8th!
tl2111 is offline   Reply With Quote
Old 07-10-2011, 07:13 AM   #1769
rias5037's Avatar
for club racing we not too concerned, so it can be done, how?
Old 07-10-2011, 07:38 AM   #1770
Pattojnr's Avatar
Trader Rating: 19 (100%+)
easiest way ....................... Brick Wall.
it isnt worth the effort. the one way up front, you will have to have a brake on each front wheel. Good luck with that. turn your EPA down on your brakes, set them so it slows the car down only, not locking up the rear.
i run on a fairly tight track for 1/8th, and i rarely use brake. only one corner really.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
