Old 06-23-2011, 03:56 PM   #1711
Lilja's Avatar
Originally Posted by Team Kamikaze View Post
2011 Rear suspension set is in stock again! but very limited quantity!
Also have a few Floating Radio tray in stock too!
Order sent!
Dont worry about the missing screws and stuff I got that covered already!
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 06-25-2011, 04:49 AM   #1712
firecat's Avatar
finally got to installing motor in new 966 carb slide hits fuel tank probably addressed this prob in earlier thread cant find any help
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 06-25-2011, 06:09 AM   #1713
Aza088's Avatar
Installed the new front end and new rear end upgrades.
Wow really wow ive never driven a 966 that has handled like this.
the car has perfect steering perfect pivot and rotation perfect rear grip. car was easy to drive i could not ask anymore from a race car.
Check out the video.
My car is the Blue and yellow.
http://www.youtube.com/watch?v=Kv4NBvXLPCk
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 06-25-2011, 07:06 AM   #1714
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
i'm having the same issue..i try twisting turning the carb and the locals guy at my track did the same and don't understand...plus i lower the tank as low it can go i thought about getting a new tank
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-25-2011, 08:49 AM   #1715
Not sure what motor your using but with Nova based motors it's very little work - start by rotating the link connection to about the 9:30 position (look directly at it and imagine the hour hand of a clock) - take .5 to .75mm off the end of the set screw boss - drop the motor into place with carb slightly loose - pull carb to open position and leave .5 to .75mm clearance to the tank - push carb down into the block to make sure the o-ring seal is compressed and tighten the pinch bolt.
Empire Racing - RC Target - Capricorn - K.O. Propo Electronics - VP Racing Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 06-25-2011, 09:05 AM   #1716
bobbyblaze's Avatar
yeah the Nova's is little work lol but RB and serpent don't mix i guess lol i had 2 sponsor drivers look at it both scratch their heads lol. i really think its the tank even w/LiFe still touching ...when i turn it one way or the other the bottom part or the carb rubbing the tank or the hex screw that hold the ball hittint the top of the tank ..so now i have rubber garmenton the tank post so the move alittle....
Old 06-25-2011, 12:14 PM   #1717
Team Kamikaze's Avatar
Send the car to me Bobby, I'll do it for you! Bet you I won't even scratch my head
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-25-2011, 02:53 PM   #1718
I had that problem with my Sirio. Just put a oring between carb and motor block so the carb is a bit higher.
Storm_PT is offline   Reply With Quote
Old 06-25-2011, 07:49 PM   #1719
bobbyblaze's Avatar
ok if i lift(Rick Way) or put the o-ring(Storm way) on the carb will that cause it not to be sealed and ha air leak?
Old 06-25-2011, 10:05 PM   #1720
Not advisable to put any extra o-ring, we have mounted Sirio, RB, Picco, Nova Rossi and most known On road engines without a problem. I'm telling you Bobby just send me the car, I'll hook you up!
Old 06-25-2011, 11:48 PM   #1721
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Bobby, I have RB, Nova new/old style carby and OS engine installed to my 966 no problem at all. Just make sure you use battery is thinner then 17mm(I am still using Nimh, no need to add weight), rotate the carby so that is not hitting the tank when slide bar is full extend also bend the linkage about 30degree, I will take a picture post it up later.
tl2111 is offline   Reply With Quote
Old 06-26-2011, 03:22 AM   #1722
firecat's Avatar
dj hooked me up this yesterday at control freakz in ct. at regionals. he heated tank corner molded it down slightly took shrink wrap off nimh dremel slots in battery tray sanded down tank spacers to 3.5 mm and adjusted carb to fit seems to work good
Old 06-26-2011, 08:48 AM   #1723
bobbyblaze's Avatar
before i do i like to try another tank first...but i am looking to upgrade my motor...i like the IDM or Picco torque but but the O.S. speed looking good as well
Old 06-26-2011, 03:20 PM   #1724
Well, if you can lower the tank as much as possible it shouldn't need any spacing below the carb. I need the oring because my battery pack doesn't let me lower the tank fully.
Old 06-27-2011, 02:24 AM   #1725
Hi,
a lot of drivers are using the orange alu sway bar mount for the 966.
I think it was available on the wc 2011.
Is there an online shop, where I can buy it?
Olli
OliverT is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
