Old 06-12-2011, 11:44 AM   #1681
firecat's Avatar
have a brand new 966 evo with all the new rear parts i also didnt get the links to couple the rear 2 speed and bulkheads no big deal must have to order as option part. my problem is the inner brake pad hits the inner rear hinge pin mount there is a relief cut into the hinge pin mount but its not enough anyone else run into this problem any suggestions beside dremel maybe a first run evo?maybe this problem was addressed?dont know any help
team scream racing/ts racing/kyosho mp9 tki3/ xray xb2 xb4/Wolcott hobbies and airsoft/rc madness
firecat is offline   Reply With Quote
Old 06-12-2011, 12:02 PM   #1682
nitrodude's Avatar
Is the break pad sitting right against the bearing block? Nothing should be hitting anything.
The connectors ARE an option part, they dont come in the kit.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-12-2011, 12:12 PM   #1683
firecat's Avatar
had pads assembled wrong had one on outside of sliders tubes all good thank god i looked a little before breaking out the dremel figured connectors were option thanks
Old 06-12-2011, 12:17 PM   #1684
nitrodude's Avatar
Thats why I asked of the pads was sitting right against the bearing block, its a bit difficult to put the pads on with the spring and in the spacers, I figured yours was hanged up on the spacer.
Steven Muller
Ronin Speed Parts
Old 06-14-2011, 02:34 PM   #1685
Lilja's Avatar
Still no sign of the new front end?
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 06-14-2011, 05:11 PM   #1686
Team Kamikaze's Avatar
Early next month.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 06-15-2011, 12:48 PM   #1687
So the new rear end only works with the new front end. Then why do they release the rear end but not front? Seems stupid.
JIM1 is offline   Reply With Quote
Old 06-15-2011, 12:52 PM   #1688
The new rear will work without the new front and the new front will work without the new rear either.
Old 06-16-2011, 04:48 AM   #1689
when installing the new upper front suspension brackets, it comes into contact with the shocks "adjusters".
remedy is to put spacers behind the front shock tower?
or did i install it wrong some how?
sammies is offline   Reply With Quote
Old 06-16-2011, 05:27 AM   #1690
Hi there,
I new around here. I have a Serpent 966 and i use the steeringblocks nš1 on the left and nš2 on the right. Is this correct or if i change nš1 to the right and nš2 to the left what will i notice on the car?
zeca is offline   Reply With Quote
Old 06-16-2011, 05:30 AM   #1691
Originally Posted by zeca View Post
Hi there,
If I am not mistaken, #1 provides more turn-in... #2 provides more high-speed steering... i may be wrong.
so your track layout will determine which (#1 or #2) is more suited on the left / right
Old 06-16-2011, 07:19 AM   #1692
Send a message via Yahoo to motojon
yes 1mm
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 06-17-2011, 08:13 AM   #1693
Lilja's Avatar
Question. Figured Id built my throttle servo in the laydown position. Doesnt seem to be parts for it in the kit however?
What Im missing is the shims holding the servo mount but more importantly the turnbuckle for the linkage?
Im also missing a total of 4 m3x10mm screws in that bag.
Seems like I also managed to get a used fueltank inside the bag, cause its full of left over fuel haha
Futaba 4PK
Old 06-17-2011, 09:34 AM   #1694
Every new Fuel Tank have left over residue, that happened when they test the fuel tank (just to make sure there is no leaks), it's weird that you have hardware missing as every kit I build for the customers have a lot of leftover parts.
Old 06-17-2011, 09:40 AM   #1695
Lilja's Avatar
I do have leftover parts just not the parts I need
Its one turnbuckle for the throttle linkages and 4 M3*10 screws Im missing. I know they arent there Ive been looking closely in every bag.
Doesnt matter though, Im occupied with the offroad atm so I havent really had time for my 966 yet.
Ill put an order in for all the new parts plus some options and the missing parts once the new front end is released.
Futaba 4PK
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
