Old 06-06-2011, 04:23 AM   #1666
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Me_MrTyson View Post
Asked the guy who I got the car from he send me the setup
996 Setup
i have been running that same setup, plenty of steering and lots of rear grip.
try the new shock extension set, and possibly see where your front sway bar is at. try softer front tyres and softer rear bar, but its way different to 12th scale. the solid axle at the rear makes the cars hard to rotate in slow corners, so you need to have a good clutch and drive it around the corners using throttle.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-06-2011, 05:41 AM   #1667
Erock's Avatar
Tyson, check your PM's
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 06-06-2011, 07:13 AM   #1668
Niky_Freaky's Avatar
Questions?? Ackerman
what is the difference between the two Ackermans
TEAM SERPENT BULGARIA
SERPENT 811b sponsored by VpPro
Niky_Freaky is offline   Reply With Quote
Old 06-06-2011, 07:36 AM   #1669
choisan's Avatar
rumor suggests that there will be a new 1/8 this year, completely new design than the current model. anyone knows about it?
choisan is offline   Reply With Quote
Old 06-06-2011, 08:50 AM   #1670
nitrodude's Avatar
966 Setup
First I would try running a softer shore in the front, so go to 32f 35r. THen try running the front sway bar flat, a harder sway bar will take steering away. One thing you can do which will have the biggest effect is to run the rear lower arms higher, when you run it higher it takes rear traction away, which will give you more front bite. Also, add more shims under the rear camber link, that will also give you less rear bite, it makes the rear of the car rotate easier. ANother thing is to run the W2 rear knuckles, they also make the rear rotate more.
Dont try all at once, go one change at a time. Like I said, try the softer tires in the front first, and go from there.
One thing about you is that you're comparing it to a 1/12th scale, and those cars always have way too much steering.
W2 offset knuckle:
description
http://www.serpent.com/product/903351/images/
Order
http://www.kamikazetoysandhobbies.co...prod=SER903351
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-06-2011, 10:13 AM   #1671
Lilja's Avatar
Anyone know when we can expect to see the new front suspension upgrade out and about? Still waiting for it to finish my car
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 06-10-2011, 06:59 AM   #1672
rias5037's Avatar
ok guys, looking to get into 1/8, could anyone tell me what the diff is parts wise between the 966 evo and the older 966, also what savox servos you guys recommend for the brake/trottle and steering.
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 06-10-2011, 07:03 AM   #1673
GREGORY!'s Avatar
really??
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 06-10-2011, 07:09 AM   #1674
Serpent is always looking to improve and make better products but for 2011 the car is the S-966
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 06-10-2011, 07:16 AM   #1675
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
i use SC-1257TG on both...evo have alot updated parts which i,m soon need to do to my 966 ...check here he have the lists of all the parts
http://kamikazetoysandhobbies.com/products.php?cat=66
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 06-10-2011, 07:22 AM   #1676
bobbyblaze's Avatar
i wonder if serpent might do the same like mugen by putting the brake disk on the rear shaft?
Old 06-10-2011, 07:31 AM   #1677
rias5037's Avatar
is there savox thats around say $30-40 that will work? on a tight budget here, heard savox was good quality servos at a reasonable price?
Old 06-10-2011, 07:52 AM   #1678
bobbyblaze's Avatar
not sure which ones you talking about?
Old 06-10-2011, 09:35 AM   #1679
nitrodude's Avatar
As much as it sucks, you really need good servos for 1/8th, these cars are FAST. Just save the money and get some good ones the first time out, it will save you money in the long run.
Steven Muller
Ronin Speed Parts
Old 06-10-2011, 09:50 AM   #1680
bobbyblaze's Avatar
+1 and i feel you on the budget i'm on the same page
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
