Old 05-23-2011, 11:43 PM   #1621
nitrodude's Avatar
Is that a brass weight between the radio tray support and the throttle servo?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-23-2011, 11:46 PM   #1622
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Sure looks like it.
Inf1nity CM Beat1 Racing
VP Powermaster
Serpent-Dan is offline   Reply With Quote
Old 05-24-2011, 01:20 AM   #1623
@ Scott Kimbrow
Thanks a lot for taking the time and sharing your experience about car-set-up, much appreciated!
Stefan
fulcrum2 is offline   Reply With Quote
Old 05-24-2011, 10:18 AM   #1624
Lilja's Avatar
Originally Posted by desotoracing View Post
Paolo's car
Havent seen all those new stuff for sale that Salven introduced at the worlds. Like the new front upper arm holders.
Anyways, asked earlier but didnt get any response. How are you guys shimming the front driveshafts?
Serpent S811 Novarossi Plus-4 BTT Futaba BLS451/452
Serpent S811T OS 25XZ Futaba BLS351/352
Serpent 966 Futaba 9451x2
TLR 22 Toro 9.0kv Futaba BLS451
Futaba 4PK
Lilja is offline   Reply With Quote
Old 05-24-2011, 10:28 AM   #1625
nitrodude's Avatar
Originally Posted by Lilja View Post
Starting to put my 966 Evo together now and have some questions.
Shimming the front driveshafts. How many shims are you using on either side? Cause the manual suggests 4 on the inside and 2 on the outside but that will give you almost 2 mm of play.
Downsides so far as Ive noticed have been, the manual is just utter garbage. Alot of filing and reaming on the A-arms to make everything travel smoothly, like alot more than on my old Mugen.
I am going to ask alot in this thread just so you know. I havent run onroad since 2003 so Im fairly rusty
I think you're supposed to use these:
http://www.kamikazetoysandhobbies.co...prod=SER903290
http://www.serpent.com/product/903290/
Steven Muller
Ronin Speed Parts
Old 05-24-2011, 10:32 AM   #1626
Lilja's Avatar
Yea I know that I have one of those on each side.
The manual suggests 4 small shims on the inside and 2 on the outside and then 1 of those big ones. But its far from enough and Im not sure on what side to put the additional 2-3 shims required.
I ran Mugen in the past and that didnt have any shimming required so Im a bit confused.
Futaba 4PK
Old 05-24-2011, 10:59 AM   #1627
I have them on my car!
VP Powermaster
Old 05-24-2011, 11:06 AM   #1628
nitrodude's Avatar
You have to put all the shims on the outside, shim it untill the play is gone. Also, make sure you install the tapered washers the correct way, the side with the smaller diameter faces the bearing so it rides on the inner race of the bearing.
Steven Muller
Ronin Speed Parts
Old 05-24-2011, 11:08 AM   #1629
Lilja's Avatar
So not even the 4 on the inside that the manual suggests?
Thats gonna be alooot of shims then
Futaba 4PK
Old 05-24-2011, 01:27 PM   #1630
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
I use the conical shim in the inside, then all the rest in the outside, as many as you need. I think that you will use all the shims you received in the kit.
Walter Diaz
wad is offline   Reply With Quote
Old 05-25-2011, 01:29 PM   #1631
Lilja's Avatar
Okay I did the same now, seems like thats what Salvens running aswell so its a good startingpoint atleast.
Does anyone know when all the new parts that were introduced at the worlds are going to be available for the public?
Figured I might aswell get those stuff and learn the car with them.
Futaba 4PK
Old 05-25-2011, 01:44 PM   #1632
Team Kamikaze's Avatar
The Rear suspension upgrade, Empire Aluminum front sway bar holder, Rear shock extension mount, Bumper and the new SL8 gearbox are all available, the only thing that is out of stock is the front suspension upgrade kit.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-26-2011, 03:03 PM   #1633
Lilja's Avatar
Sweet, as soon as the front suspension upgrade kit is available Ill put in an order for that, the new rearsuspension rebuild and shock extension, bumper and the new gearbox. Aswell as the aluminium radioplate bracket, the adjustable rear swaybar and the aluminium bodyposts.
Btw aint there supposed to be a new brakedisc pulley aswell? Cause I think I have the one with two pins but theres supposed to be one released with the update kit that has 3 pins.
My local dealer has already boycotted me cause I bought the car from you so it doesnt really matter anymore where I buy spares and options either
Futaba 4PK
Old 05-26-2011, 03:11 PM   #1634
Don't worry Sam will always have the latest parts first anyway!!
VP Powermaster
Old 05-26-2011, 03:33 PM   #1635
Originally Posted by Serpent-Dan View Post
Sure looks like it.
Yes they are. this are Ronin Factory parts!
Serpent, Picco, Desoto Racing, Sanwa, Byron Fuel, Matrix, Avid, Arrowmax, Xceed, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
