Old 04-30-2011, 09:55 PM   #1561
Team Kamikaze's Avatar
Originally Posted by Serpent-Dan View Post
I believe it needs to be more like 21mm
No not 21mm
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-30-2011, 10:29 PM   #1562
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
21mm wow is that too much? but i switch to my old Frizbee body the car ran good and the rear was tab bit loose but controlable.....i hate thet stop making that body..lol
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 04-30-2011, 10:39 PM   #1563
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Sam how far was it again? I forgot what you had told me.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-01-2011, 12:58 AM   #1564
14mm in front of the bumper, but on the R11 just mount it where the dimples are.
Old 05-08-2011, 01:33 PM   #1565
bobbyblaze's Avatar
i think i found out why my car was pushing i lost the center bushing in the rear shock tower
Old 05-08-2011, 04:13 PM   #1566
Just a quick question on setup -
What effect will it have on the car if I change the position of the rear upper arm on the uprights?
Thanks!
JIM1 is offline   Reply With Quote
Old 05-08-2011, 08:13 PM   #1567
Send a message via Yahoo to motojon
Thanks!
Changes camber rise
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 05-09-2011, 01:06 PM   #1568
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Thanks!
If you add more shims, it will rotate more. Meaning more steering.
If you lower it (less shims), the car will have more rear traction, but it will have less steering...
Walter Diaz
wad is offline   Reply With Quote
Old 05-09-2011, 01:11 PM   #1569
Thanks!
Old 05-13-2011, 08:56 AM   #1570
Guys, I am just in the process of building up the rear end of my new 966.
Is it correct for the rear axle to have movement of about 1mm side to side? Seems as if the bearings need to be wider.
Thanks!
Old 05-13-2011, 09:27 AM   #1571
wad
wad's Avatar
Thanks!
It should always have a little play, 1mm seems to be a lot, if the bulkheads are already installed in the chassis and the play still that much, you can add some shims.
Walter Diaz
Old 05-13-2011, 09:27 AM   #1572
Thanks!
there should be a 1mm shim that goes between the pin and the bearing.......it shouldnt be real tight, but u should be able to move it ever so slightly
My Gpa(RIP)
Old 05-13-2011, 10:52 AM   #1573
bobbyblaze's Avatar
i just notice on my car i'm taking the front end apart to replace a belt... i have the same amount of shims on L/R side but the left side has more play than the right ...thought about adding more shims is that ok?
Old 05-13-2011, 10:59 AM   #1574
as long as it doesnt make it too tight where theres drag......if u cant get it just right get the kyosho wheel shims the have .2mm & .5mm shims to find the perfect freeplay
My Gpa(RIP)
Old 05-13-2011, 08:54 PM   #1575
bobbyblaze's Avatar
thanks for the help...think Sam has the shims?
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
