Kyosho Starter Box
I just bought a kyosho starter box for my HPI R40. Having a hard time generating enough power. Any suggestions? I know it requires 2 7.2 volt batteries. Does it matter how many mah the battery has?
Thanks |
The voltage will dictate the power and the mah will determine the run time. If you are breaking in a new engine or have a tight pinch on it, it would be a good idea to warm the engine with a heat gun before you start it. You might have to loosen the glow plug a touch to ease the compression as well.
Originally Posted by dvu
(Post 5263041)
Thanks |
i was able to fit a 12v gel fits snug inside but gives it a good kick to turn the engines
