Old 01-24-2002, 02:14 PM   #1
Send a message via AIM to tone
OS 21 RZV b99 need HELP
I have a OS RZV b99 21 that's giving me HE*L . This is a new moror only 8-tanks in. It say on the top all the way in and bring out 3-turn when I do that it won't start up. But when I put it at 1-1\2 it will start-up and run. But after it runs out of gas it won't start back up I need some help very bad. If you can any-boddy I need the break-in and after break-in settings. (HELP)
tone is offline   Reply With Quote
Old 01-24-2002, 07:06 PM   #2
Motorman's Avatar
are you sure the tuned pipe pressure line is attached? otherwise change the plug and try it again. I have seen bad plugs that glow and look ok but they have been contaminated with silicone and wont run properly no matter what you do.
it sounds like the motor is lean for some reason and is overheating. the factory settings are only good for initial startup. you have to tune it properly or it will overheat. the factory settings are just an arbitrary value as I said and if you think those are the qoute right settings all the time you are mistaken.
how hot is it getting???
Just here to give the world grief.
Motorman is offline   Reply With Quote
SEO by vBSEO 3.5.0
