Old 10-23-2003, 04:33 AM   #31
Taylor-Racing's Avatar
Originally posted by InitialD
Yes, I talked about it in the engine wars thread but I was actually enquiring if anybody changed the stock bearings in the engines to ceramic ones and noticed any difference...
Because ceramic bearings have the added advantage of being able to spin faster with less resistance and rotating mass?
Cut and paste from Motorman's past post;
Yes I have used them (ceramic bearings) since before boca went public with them. They are excellent and will outlast the rest of the engine. I wish they would let us use them in Roar legal engines as I have toasted a motor or two due to bad bearings myself. The initial cost is neglible nowdays compared to the cost of other RC car parts. If it saves an engine its worth every penny.
PS I have never had or seen one fail, EVER!
So my guess is that they are illegal under ROAR but legal under IFMAR?
Ahhh OK, my bad.
The discussions I've had recently with some bearing people support what Motorman seems to say.
Thay say the main advantage of ceramic balls is the greater load carring capacity since the ceramic balls don't deform significantly. The other advantage has to do with the running of a steel ball in a steel track in a poor lubrication environment - essentally galling.
I find it odd that ROAR found the need to specify bearing types.
It would be beneficial if ROAR revisited their rules, I think.
They were leading the way with a set of rules when IFMAR only had a nonsensical "draft" set of rules. Now IFMAR have finally decided on a decent set, it's about time for ROAR to fall into line.
Taylor-Racing is offline   Reply With Quote
Old 10-23-2003, 06:23 PM   #32
AMGRacer's Avatar
Ceramic bearings are not illegal in Australia under our subset of IFMAR rules.
AMGRacer is offline   Reply With Quote
Old 10-24-2003, 10:23 AM   #33
popsracer's Avatar
Default RB engines
Just wanted to say that I ran my RB-V12 (#1700-410) yesterday in practice and am impressed with the power.
My Buddy has a MR12 Turbo and only had a slight edge at the end of the straight away.
popsracer is offline   Reply With Quote
Old 10-24-2003, 07:41 PM   #34
Fisher890's Avatar
Hey pops which 12v you running?what are you running it in?
Fisher890 is offline   Reply With Quote
are the ofna force engines any good? jatoman1992 Nitro Off-Road 34 05-11-2010 07:12 PM
WTB .21 to .28 engines good or bad vintagetamiya R/C Items: Wanted to Buy 13 12-27-2006 06:23 PM
where to get good deal on engines in HK dodo Hong Kong Racing 0 05-09-2005 07:06 PM
Good engines R3DRUM Onroad Nitro Engine Zone 1 06-22-2004 08:09 PM
Ofna/Picco 12 R Engines, are they any good? elmar66 Onroad Nitro Engine Zone 1 06-16-2004 07:13 PM
SEO by vBSEO 3.5.0
