MTX 5
#1171
For those of you who are having trouble with the new clutch here is what Ive found thats works really well. I used the silver mugen clutch spring and tightened to 1.4mm. Set the end gap to .70mm. I trimmed the corners on the sling weights as to allow them to come out without rubbing each other. Try to experiment using more or less tension on the spring and .6-.7 gap on the bell. I like to take the tension on the spring to the point where the clutch slips and than I back it out a 1/4 turn. good luck
#1172
not a lot of trouble, on the infield the clutch was super! but on straight when the car hit the secong gear it begins to slip but I am working on that! or that is what Juan told me with his advise!
btw thanks for the battery advise!!!
#1173
sorry double post
#1174
Yes I did try the MSR spring. It seemed to have too much tension for this tiny little clutch. I feel like the stock spring is heavy enough. i think the parts are so light and tiny they do not have the weight to properly engage the clutch. I tried and tried the MSR and changed it out only to find that it was to hard. The MSR will work but I could not get it to work as well as a spring with less tension.
#1175
The BMX track quote is perhaps a slight exaggeration; but basically true, and our assessment agrees with Daniels. Our car traction rolls with the hard springs that we used to run with, but is perfect when we go a little softer.
The setup discussion on this thread is awesome, and I'm taking notes for future reference every day. The copy and paste function is working overtime on my computer. Thanks for all the contributions.
Kindest regards,
Lars.
Kindest regards,
Lars.
It is good to see, but Lars this setup info is for a MTX5 not a Goat!!! lol
#1176
totally agree Luis. Most people seem to think that a basic setup means "it works everywhere". Also what i noticed sometimes in RC is you have idiots who are quick to talk to people condecendingly when they don't try the basic setup .As if it's some sort of neccessary requirement to use it at least once.
I feel sometimes people in RC don't think outside the square with setups and blindly do what the quick guys do thinking it will work for them. I have a mate of mine who has told me " i don't fool around with setup anymore i do what the quick guys do"
sometimes this works, but most times it doesn't because people don't think about setup and WHY a certain setup will affect the car.
Also i see a lot of people not trying all setup options, just the basics like springs and oil and toe and camber...there are a mountain of extra setups options that can fix problems.
Bishop, you say the car handles ok and it is quick, yet you have some small problems on exit on throttle. Mate, don't go soft! a soft setup on a fast bumpy track like Brendal will just feel atrocious! go with a dark blue or higher spring setup, also like Dan said go with a narrow track width left to right. go 198 rear 195 front (or as narrow as you can front and rear).
on the S section after the front straight make sure you always stay on throttle and never back off totally otherwise witht he bumps in that section the car will spin out there. Stay on throttle and never back off totally, do this all the way until the back straight.
If i was you i would go dark blue springs front and rear, with standard oil, two holes. Try anti squat on the rear with stiffer rear bar and thinner front bar
the anti squat on the rear will keep the car planted on throttle on exit. (anti squat is the rear arm angled towards the back ie; the lowest pin position on the rear and middle or highest position ont he engine side. This keeps the weight on the rear arms).
You might find you can raise the rear shocks with anti squat.
Also go long rear links with no washers or 1mm washers only on the outside. Longer camber links give more grip and the reduced washers means less camber change.
also try raising the front arms after all of this and see what it does.
Also remember casotr affects exit reaction of the car.
Regards
Les
#1177
too many people in this hobby, and i see it especially with the Aussie guys follow what the quick guy does like sheep. this is a hobby, and what someone does with their setup is their business and the discovery element is all part of the fun...many Aussie guys forget this element of the hobby and berate other racers when they try something different.
i'm known for doing some silly things with my setups, but really...who gives a toss what i do Are children in Africa dieing because of my setup options ...no...so who cares Some Aussie racers especially act like kids are dying when someone says;
"i didn't use the stock setup"
more people need to have a laugh and fun in this hobby. It's not about how much cash you spend, or how many wins you get, it's solely about how much fun you have...and if this means that you want to run yout shocks upside down then so be it we should be confident enough to not really care, but conscious enough to see how people act.
#1178
Well, finally the X5 has arrived in Europe and I started to build my car.
On the first steps you just recognized that there are these littles things which make the difference.
Just have to finish the car until friday, because we have a race at the weekend.
#1180
Is good to know because a close friend did something to the diff and I could be a possible cause that he inverted the covers
#1181
ok, just talked to RP. he told me that the covers have a difference of +-1mm to itīs necessary to install them correct. he also gave me the tip to glue the brake disk adapter
#1182
info
Hello, I am going to buy the mugen mtx5.
I would like to know who uses it if you are experiencing particular problems.
fragility of the frame?
fragility of the crowns?
differentials?
I look forward to your advice I change my NT1
differentials?
#1183
#1184
#1185
I thnk the NT1 is a cool car the runs good but no pressure!!!
