Old 10-13-2008, 07:36 AM   #1
Default Noob question abt suspension and tires...
to maintain the same levels of grip with a car on harder tires will require softening of the suspension and the opposite is true for a car with soft tires right?
so the question is is there any difference between a hard sus/soft tires setup and soft sus/hard tires setup?
katze is offline   Reply With Quote
Old 10-13-2008, 07:50 AM   #2
wingracer's Avatar
Trader Rating: 21 (100%+)
It's not just the tire compound that determines the needed spring rate. It's total grip which is a combination of tires and track surface.
If you are running soft tires it is usually because the track is slick which means you need soft suspension as well. As traction comes up you may need to go to a harder tire. If traction really comes up (someone just sprayed VHT all over the track) then it's time to go harder on the springs as well.
That's just a bit of general theory. Every car/driver/track is a bit different.
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 12:14 AM
OFFICIAL DURATRAX VENDETTA THREAD... jaejw1 Micro and Mini Scales 3209 12-24-2014 12:37 AM
R/C Car Tuning Lesson 1: Tires artwork Colorado Racing 14 11-21-2014 07:43 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
SUSPENSION 101 Losi Motor Man Rookie Zone 1 04-17-2007 06:40 AM
SEO by vBSEO 3.5.0
