Old 09-21-2003, 11:08 AM   #1
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
Default combating RUST
How do you guys combat rust?
I just finished assembling my nitro car, haven't even started the break in process yet, and I am already seeing some rust on the screws..!!
Here in Hong Kong, it is extremely humid...!!
Would appreciate all ya input!
lawndoggie is offline   Reply With Quote
Old 09-21-2003, 12:51 PM   #2
Dan's Avatar
Trader Rating: 40 (100%+)
Are you leaving water on it? I don't think most of us guys have problems with rust. Just replace the screws if they become bad enough, they're cheap anyways. I have some rust remover that I bought for my real car and that will removed some slight surface rust as well. But even the cost of the bottle will pay off for tons of replacement screws.
Just don't get the bearings wet. They'll rust fast and you'll need to clean them out again because it will lock them up.
Dan is offline   Reply With Quote
Old 09-22-2003, 08:38 PM   #3
Send a message via AIM to 2mcgrath Send a message via Yahoo to 2mcgrath
i would say get some wd 40 or some kind of oil to protect against rust and just put some on a rag and wipe your screws down..is it the heads of the screws or what that is rusting...
2mcgrath is offline   Reply With Quote
Old 09-23-2003, 10:33 AM   #4
popsracer's Avatar
I would worry about the Inside or your Engine rusting before the Screws. Make sure you always run the Engine dry and use After-run Oil when you finished for the day.
popsracer is offline   Reply With Quote
OMG Rust in Fuel Tank! Dragon Nitro On-Road 7 06-15-2005 08:55 PM
Screw rust..... Cardboard Electric On-Road 1 05-30-2004 01:28 PM
removing rust elmer20 Electric Off-Road 1 11-13-2003 09:14 PM
crank rust MCRUZ Nitro On-Road 6 04-03-2003 11:06 PM
SEO by vBSEO 3.5.0
