Old 09-27-2008, 11:16 AM   #1
Default Full throttle
Quick question. If I'm already moving an then I go to full throttle no problem, but if I'm at stop and go full throttle, my car will due. Is it too much gas or not enough gas?
dvu is offline   Reply With Quote
Old 09-27-2008, 11:56 AM   #2
Riketsu's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to Riketsu
Means the low-speed needle is not set right... I cannot tell you if its too lean or too rich by the description your giving me...
The way I usually set the low speed needle is: Start the engine, and get it to operating temperature... Rev it a few times just atleast 1 second after I hear the 2nd gear shifting. Leave it standing still for 10-15 seconds, then go full throttle. If its too rich, your engine wont cleanly rev up. Another way to check if your engine is too lean (LSN), is do the fuel line pinch test. Pinch the fuel line near the carburator inlet and count how many seconds before you hear the engine rev up... If it revs up in less than a second, its too lean... A good low-speed setting should be 2 seconds without hearing the engine rev up.
eBay user id: riketsukirai
Selling all my MTX4 parts, bodies, radio and everything!
Riketsu is offline   Reply With Quote
Old 09-27-2008, 10:55 PM   #3
if the car is moving and the engine is idle when you give full throttle and the engine does not die, then I'd check the clutch... it may be engaging too soon.
gortan is offline   Reply With Quote
TC3 Forum Lowrider Electric On-Road 12151 10-07-2016 12:37 AM
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
Full Throttle Speedway !!! TimPotter Florida Racing 799 02-27-2005 04:51 PM
2004 IFMAR ISTC & 1/12th On Road Worlds at Full Throttle Speedway AdrianM Electric On-Road 2162 12-29-2004 03:09 AM
South Australian Electric On-Road State Champs R32GTR Australian Racing 260 11-24-2004 02:53 PM
2004 On Road Worlds Warm Up & Worlds At Full Throttle Speedway AdrianM Electric On-Road 418 05-05-2004 09:38 AM
SEO by vBSEO 3.5.0
