Streetforce
Streetforce
Anyone know how to adjust the gear ratio on the Street Force? It says something about higher gears and I'm puzzled.
you just change the pinion or spur gears to change it.. you will have to order the different gears for it from tower hobbies.. which would probably be the better place to pick them up at..because stock gearing that thing is really high geared..
yeah call tower hobbies and ask them what kind of configuration they have for the street force gears...remember the higher the number the lower gear it is for more bottom end........the lower the number of teeth on a gear the higher the gear ..for insane top speed .......what r u looking for top end of better take off??
