Old 09-10-2003, 11:11 PM   #1
Default Help M8 and ALB
I Can't get this feature to work!!!!
Que is offline   Reply With Quote
Old 09-10-2003, 11:28 PM   #2
InitialD's Avatar
Default Re: Help M8 and ALB
Do it at your own risk !!
First you hold down '+' '-' and '>' buttons.
At the same time, turn on the remote using the 'display' toggle or 'on' toggle switch. That will bring you to the Setup Mode.
Use < and > to scroll through the various menus. Use * button to enter the mode. Press < to go to the 'COM' menu. Press * to enter. Then press + or - to to turn the ALB on and off.
Now, turn your remote off and on again. If you try scrolling through the menus, you'll find the ABS menu.
SEO by vBSEO 3.5.0
