Ultra GTP tires
Ultra GTP tires
I need some advice for new Ultra GTP tires. I was doing donuts the other day on my all but worn out slicks, and the foam just shot out the side.
There are so many tire choices. I need advice on a good tire set that is for street use and parking lots that will get good traction in turns but also last. I am not too keen on foams because I like to drift and spinout a lot. I am not clear on the size that I need either, there seems to be so many choices for 1/8 scale onroad!
Anyone got any ideas?
Ipanema Pre-Mounted Radial Racing Slicks
running 50KF-15KR in my gtp2 and having a issue with the rear end sliding out when exiting a turn..any tips anyone?
also using 2k front shock oil and 1k for rear shocks,eveything else is as per manual.
ok thankyou will do
