Old 09-03-2008, 05:39 PM   #1
superhornetrace's Avatar
Default slicks VS foams?
i just got a ofna gpx4! its a beast!! it came with foams but soon ill need ones.
what are foams good for? and what does firm and all those mean/good for?
same thing about slicks
superhornetrace is offline   Reply With Quote
Old 09-03-2008, 11:33 PM   #2
NiTrO BoOsTeR's Avatar
um with foams they are really ment for racing, or smooth surfaces, if ur running in a parking lot then rubbers are the way to go, if running on something like a tennis court either would be fine, the rating on the tyres is a scale and the lower the number that means they are used in cold weather and on low grip, and higher number means they are used in hotter weather, and on high grip tracks, it tells you when the rubber/foam is the grippyist
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
Foam Setup VS> rubber setup Hpimichael Nitro On-Road 28 06-04-2009 02:28 PM
who thinks they should make 30mm slicks for the touring cars? baller360 Nitro On-Road 66 01-13-2009 12:08 AM
SLICKS VS. RADIALS HUCKMAN Electric On-Road 22 05-01-2008 09:40 PM
Rubber vs Foam Tires - let the battle begin! black-knight Australian Racing 385 08-31-2004 11:59 PM
Parking lot practice vs racing RE:traction imjonah Electric On-Road 12 04-25-2004 10:04 AM
SEO by vBSEO 3.5.0
