new TC3 starter box problems
hey guys,
yesterday the guy at the local hobby shop convinced me that i needed a starter box. so i bought a brand new Team Associated starter box.today i went to try it out.i hooked it to my car battery just like it said,put my car on it and pushed down and it wouldnt even turn the motor over.so i looked under car to make sure the flywheel on starter was hitting the flywheel on car,everything looked good so i pushed down again and the motor on starter just started pouring smooke out.i pull started my engine and drove my car around for a while and tried it again with same result.what am i doing wrong?
thanks in advance BUDRACER1
get the ofna box. its a knock off of the tc3 box but has an on-off switch, the bump out on the side is much smaller, has more torque and and abec 5 bearing. it also comes with plugs/clips to run it off of 12v.
its awesome. i love mine
its called a bump start for a reason
i haven't had any problems with mine, and im running a MR-12 with less than a gallon of fuel through it
make sure the piston is not at TDC
