Bearing Manufacturers?
Sup guys, Im trying to look for some bearings for my Novarossi 12-3SCT. I tried www.bocabearings.com but they do not carry the bearings I of this engine... Here are the dimensions I'm looking for:
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Thanks in advanced...
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Was looking for a similiar website as Boca Bearing. Was looking for the generic Rear bearing, not the ceramic one. Not willing to spend $90 on just one bearing. Unfortunely Kamikaze does not have the 11.9mm bearing, they do have the 11.5mm... (Thats on the website)
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Front Bearing:
OD:18mm
Width:5.3mm
Rear Bearing:
OD:21.4mm
Width:5.3mm
Are you sure it is not 5mm and the caliper is off. Or maybe not having the caliper seated all the way or what have you. .3mm is not much and you may be able to misread this as being a 5.3mm. I do not know but the last time I checked the bearings they were 5mm wide. Maybe I am wrong but something to check I have never seen a 5.3mm wide engine. i know the Novas were running the 11.9 and also the 11.5 but they were 5mm wide. Maybe something new.
try endurobearings.com just send them an e-mail in their contact us section they make really good bearings in a large range of sizes..
Try this guy. He should know which bearing to use in non ceramic.
http://www.murnanmodified.com/index....sort=2a&page=2
Those are some oddball sizes. Nova is famous for doing that sort of thing.
Yes, they do that to be sure people have to buy the bearings from them and so can set high prices.
Only place I have found it has been the border r/c.... But the shipping to my country is ridiculous for a bearing, 12.5EUR... Seems I'll have to buy the ceramic one. I sent an email to toro_man from Rc-toro.com and hes going to check if he can get it... I'll let you know.
