Question on Novarossi C12 >
Old 09-25-2003, 12:26 PM
Default Question on Novarossi C12
Can the threaded piece of the crankshaft be replaced or must I buy a new crankshaft? The reason I ask is someone might give me an old C12 but it has a short shaft (running in a RC10GT) and I need a standard length shaft for an HPI car.
I think the threaded piece on the MT12 can be replaced but I'm not sure on the C12.
TIA.
Jim.
jimbonj is offline
Old 09-25-2003, 07:15 PM
mckrooz's Avatar
Yes, I believe it can be replaced. You don't have to buy the whole crank shaft. I don't have a part # though.
mckrooz is offline
Old 09-25-2003, 08:05 PM
I had a MT12 and the it was just a stud and think the rest of Novarossi cranks are the same way, just be very careful with how and where you hold the crank while removing the stud.
rwjso is offline
Old 09-28-2003, 05:48 AM
TAW
Trader Rating: 18 (100%+)
I picked up a few 5mm phillips head screws at the hobby shop that work perfect for this, just screw it into the crank and cut it to the right length. About 20 cents a peice....
TAW is offline
