JACO Prism wheels win GLC
A big "thank you" to all the drivers who ran JACO tires at the Great Lakes race this past weekend. I would like to congratulate Josh Cyrul for his win in 1/8 and TQ in 1/10 sedan. Also congrats to Bobby Flack, the winner of 1/10 sedan, and Andy Power who helped make it a JACO 1-2-3 sweep in sedan. The top 3 finishers in sedan ran the new Prism 1.5 wheels with the molded-in camber.
Do you know what hardness they used in qualifying and what they used in the mains for sedan.
Josh told me he ran 45 rears and 38 fronts and Bobby ran 42 rears. You can typically run a little firmer tire on the rear since the Prism wheels should get more bite than a standard wheel.
Hi Jack,
Should I cut the prism tires cambered? In which positions is the performance better? Waht do you prefer for my mechanic camber. Should I reduce my mechanic camber. I usually use 3 deg camber on my local track with normal tires. If use the prism tires , does it mean I have to reduce the camber on the car.
thnx
thnx
Hi Jack,
thnx
thnx
Andy Power
Now if only customs would release my tires in Portugal, our team could actually run them.
They arrived last Wednesday and are still in customs. Unbelievable.
Hi Jack,
thnx
thnx
I ran 1/10 prisms for the Region 1 regionals at nercar and took 3rd . thanks Jack great .tires
Renato Dias
Renato Dias
Great job, guys. Thanks so much for using our tires!
