Old 07-31-2008, 02:23 PM   #1
Default Dry lube WS2 Tungsten Disulfide
Opinions wanted.
Boca bearings offers Tungsten Disulfide dry lube for all their products. They say it will greatly improve performance. My company ordered 45lbs for testing, and I took a lb home for myself. The company is using it to improve the life of air pumps. We have been told we could get another 3000 hrs out of a commercial air pump from the application of the dry lube to pistons. I have applied it to my bearings and fittings and all the rod-ends and balls. It greatly improved everything. The suspension is smoother and all the part role much easier. So I have begun to use the stuff all over the house in a 20% alcohol mix. No more squeaking doors or cabinets. So far this stuff is amazing. I was doing some reading, and the stuff I have is .4 microns powder. If I applied it to my piston head and rod, is there enough tolerance to allow a .4 micron layer of dry lube to help reduce the stresses of friction from engine break-in. This stuff can handle pressures of 300,000lbs/sq-in at a .03 Cf of friction. Temps to 750C. PT-FE or Teflon has a .1 to .16 Cf of friction. without the pressure and heat tolerances. Anyone have any thoughts, or do you just want me to try it out and explain my results.
Relay8039 is offline   Reply With Quote
Old 08-03-2008, 06:23 PM   #2
dougday's Avatar
Please continue to test and post your results
dougday is offline   Reply With Quote
Tungsten Disulfide engine pre breakin Lubricant Relay8039 Onroad Nitro Engine Zone 14 12-28-2010 08:50 AM
Like new Palm One Tungsten E2 PDA for sale R@ge Other Items: For Sale/Trade or Wanted to Buy 1 03-07-2007 07:39 PM
FS/FT NIP Tungsten E2 W/ Upgrades! madmarty45 Other Items: For Sale/Trade or Wanted to Buy 0 02-24-2006 02:39 AM
palm tungsten T5 ahsikes Other Items: For Sale/Trade or Wanted to Buy 1 02-20-2006 02:17 PM
Tungsten Carbide Tire Rounders anyone??? rayhuang R/C Items: For Sale/Trade 16 09-19-2002 11:04 AM
SEO by vBSEO 3.5.0
