Old 07-30-2008, 07:20 PM   #1
tomkelley's Avatar
Default back pressure effect on performance, mileage, - max power back pressure adjustment
I noticed this setup on Red RC:
This looks really simple to do, all I had to do was take a high-end needle fitting off an old carb, and fit inline with fuel tubing (not threaded on like this one here), and test for air leaks.
Now that I have done this, could some one answer my question, what effect does increasing/decreasing back pressure have on performance/ fuel mileage?
Detroit Radio Control Car Club
tomkelley is offline   Reply With Quote
Old 07-30-2008, 07:36 PM   #2
Trader Rating: 14 (100%+)
Just thinking out loud:
Less pressure going to the tank, fuel flows slower to the carb, leaner mixture, more fuel mileage. Also there when you get off throttle, there won't be a sudden surge of fuel going to the carb. I've read a test in a magazine before of the Drake running 1/10 truck without the pressure line going to the tank.
I think thats what the Orion CPD funtion is. It keeps the pressure constant throughout the entire throttle range. When you get off throttle the excess pressure goes into the rubber bladder and slowly bleeds back into the tank. When you get on throttle the rubber bladder opens up and dumps the pressure back into the tank faster.
Speedpassion : Speedpower : East Coast Bodies
thunderbt3 is offline   Reply With Quote
Old 07-30-2008, 11:26 PM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
It is an old trick I have been experimenting a lot with.
A lower pressure in the tank does have some advantages, one of them is you make the engine less pressure sensitive and so any leak in the exhaustsystem while racing will have less influence.
The main advantage is when you are on top speed and brakes into a corner the pressure from the exhaust still wants to push a lot of fuel into the engine which will cause the engine to pickup very rich after the corner, that will cost you fuel. Leaning out on the LSN will not help because you will go to lean in other situations.
Lowering the pressure will take away that bit of push when letting go the throttle so you save fuel and you get a faster engine going out of the corner without any hickups.
A disadvantage is when taking away that push of fuel you also take away a lot of cooling. With the new EFRA exhaust pipes it is normal to run on 130 degrees celcius, taking away some pressure it did raise up to 145 degrees
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 07-31-2008, 04:06 AM   #4
wingracer's Avatar
Trader Rating: 21 (100%+)
Where should one start at on the needle?
Sean. Certified speed crazed mowron.
Team Shepherd USA
wingracer is offline   Reply With Quote
Old 07-31-2008, 04:12 AM   #5
Roelof's Avatar
Adjust the engine with the needle open, then turn the needle in to a point you notice the engine is getting leaner. from there you have to play with the pressure, main needle and mixture needle.
Do not go to far with closing the pressure, then you will cause vacuum inside the tank...
pressure line karimbs Onroad Nitro Engine Zone 3 01-03-2007 01:24 AM
Pressure Chamber what is it for??? BeBop Nitro On-Road 8 10-21-2006 07:25 AM
Pressure chamber TRAJ Nitro On-Road 12 02-05-2005 03:58 AM
Fuel pressure DrIfT'R' Onroad Nitro Engine Zone 1 05-21-2004 08:36 PM
xxx-nt back pressure line freeman Electric Off-Road 12 02-07-2004 12:53 PM
SEO by vBSEO 3.5.0
