Rc10ntc3
#8911
Trader Rating: 21 (100%+)
The "old" NTC3 is still winning races! The Z12R-powered NTC3 of Fabian Kaloustian won the first race (out of 3) of the 2006 Brazilian National Championship last weekend. The race took place in Rio de Janeiro, at the Rodeo Drive track, that has one of the biggest straights in Brazil (more than 260 feet long).
#8912
dohc91crx-I used associated standoffs (originally for L series cars and long flat head screws) to accomplish the same goal. The longer standoffs are all you need, a couple of screws and your set.
#8913
cool! i am going to do some research on where I can get them and which screws I need. Thanks for the info!
#8914
Originally Posted by PSiDAWD
so how do you adjust the stock clutch to engage sooner?
I dont think the clutch shoes are the issue with yor car.
#8915
yeah you want it shifting later though...so the RPM builds up and you have better punch....with my NTC3 i drilled out a hole in each shoe to make it lighter and i put the harder springs so it loads up with RPM then just takes off it works really well especially witht he FT three shoe clutch system
#8916
RTR Universals
Hey does anybody know if you can get the axles seperately? I've looked around but am unable to locate?
dohc91crx-the flathead screws need to go all the way through the transmission case and extend about a 1/4" or 4mm.I think they are 2 1/4" but measure to be sure...
#8917
i know this isn't the for sale forum but i have 2 FTNTC3's with alot of extras for sale. it totals over $1600 worth but i'm asking $650 obo.
pm me if anyone is interested
#8918
I just bought a brand new orion wasp .12 se-ps drone engine. Part number 80061- This should be an awesome motor just for back yard bashing and should be much better than ae's stock .15, right? the box says it is 2.11cc, 34000 rpm, 1.25hp. I wanted an OS and had the money but the guy sold me this instead. I think they are being discontinued? I only paid 79.99!
#8919
Just thought I would share this. I have already bought mine and am witing for it to come in.
http://cgi.ebay.com/Ultra-Lite-Drive...QQcmdZViewItem
It is a one of a kind driveshaft that is actually about 30 percent lighter. The stock weighs like 12.6 and this one weighs 8.4 grams.
So now I am going to go for light weight. I am now going to buy a lightweight hub and a lightweight chassis. I can not wait to go non pullstart so I can get the lightweight flywheel. I bet after all that I will be keeping up with the belt driven cars.
#8920
Well I installed the driveshaft today and it fits perfect. I can see a difference. Will going to non pullstart and swapping to nonpullstart parts make that much of a difference for acceleration and/or top end?
#8921
dohc91crx-I've got to think it's better, lighter and faster...It's just more expensive, but I think the convenience outweighs the expense...Good luck.
#8922
I actually won it at 7 dollars and some change!!! The buy it now's that he does are priced at a whopping 16-17 dollars plus shipping- just wait till the last minute and bid on one that is not a buy it now
#8924
Originally Posted by aussie racer
so does any one know out there if there is an optional 2nd pinion that can be used on the ntc3 clutchbell that is a 28 tooth as am needing one.........
#8925
i know this isn't the for sale forum but i think someone might be interested.
over $1600 in stuff for $525 shipped to the lower 48 states
2 Factory Team NTC3's,carbon fiber top plate,extra chassis,2 exhaust pipes,3 extra complete diffs,flat factory team anti roll bar,3 thick aluminum drive shafts,lightweight aluminum drive cup,front one-way,kfactory centax clutch set,kimbrough spur gears 48t,50t,54t,ae spur gear 52t,1pk pivot balls,std clutch shoe spring 4 sets,stiff clutch shoe spring 4 sets,polished hinge pin set,3 shoe fly wheel,2 shoe fly wheel,1pk rear hub carrier,1pk rear arms,5 ea front steering blocks,factory team light weight 2 spd clutch bell, kfactory low profile motor mounts,3 extra clutch bells,pinions 22t,26t,20t,27t,4 pks clutch shoes,rear exhaust mounting wire,3 extra clutch nuts, lightweight brake disc,brake disc,2 front arms,1- 2spd housing with bearing,1 one-way hub,1 fuel tank,8 socket caps,8 blue aluminum cvd,1 pkg blue aluminum cvd,1 pkg blue aluminum cvd with axles,4 ea cvd axles,1 bulkhead,2 wide front bumper mounts, and more.
FOR PICS LOOK AT THREAD: 2 Factory Team NTC3 (very cheap)
