Rc10ntc3
#7486
Originally posted by tommi
I personally felt that the car handles more stable on the rear, more options to play around with the roll center, and most importantly...no more ball-cups linkages popping out when you spin out and crash your rear end or you get rear-ended. Go get it, the look of the V2 rear suspension already looked fast without running it on the tracck..
haha.hey tommi,do u use wire type roll bar at the front?
#7487
Originally posted by adamkerrnz
Hello,
I am contemplating selling off my kyosho v-one-rr evolution chassis in favour of a NTC3. i know of one guy who races a NTC3 and i am really starting to like this car
I am thinking of getting the factory team kit and using my old OS.12TR engine from the v-one in it eventually saving up to get a sirio or picco engine.
are there any faults in this car at all? and is there anything else that would make the car run better than it already does?
Thankyou for your help
Adam Kerr
Hello,
Adam Kerr
aiyah.somebody gonnae get a factory team kit liao jealous jealous
#7488
#7489
With the money from my v-one-rr chassis and some serious saving :P
i am jealous man.mine is just an rtr with some hop ups
#7490
Adam Kerr
Adam Kerr
I think the Kyosho RR you were/are running has a centax clutch?....bear in mind the NTC3 Factory Team uses a 2 shoe clutch, so you may want to "upgrade" this to get the adjustability of the centax clutch.
Theres a few nice K-Factory hop-ups available to enhance the NTC3 mentioned in previous posts here.
Cheers
#7491
MT12 flameout / high temps
I post this in the NTC3 thread, because I don't have these problems in my AD2.
I have a recently broken in MT12 in my new FT NTC3. The problem is engine temps are above 270 without a body. I slowly richened up the mixture, but the motor will then flame out. Is this normal behavior for this motor / car? I've had MT12s in my XXXTs for 3 years, and I've never had temps near this high.
I don't have these problems with my AD2. Which leads me to beleave I goofed something in assemble of the NTC3. Car seems to be a rocket, though.
Thoughts?
Thoughts?
#7492
Hows the clutch? Is it sticky or nice and smooth? What kind of plug is it Turbo or Standard you could try and go to a hoter plug.
#7493
my MT12 has a standard plug. The clutch is silky smooth. The wear is normal - very little on the inside of the housing or shoes. No evidence of slipping or rough engagement.
#7494
hi guys. i am new to nitro on road, but not to rc racing. i got a second hand ft ntc3, loaded with extras. the only question i have is this: if i went from a 48-54 gearing to a 48-52, what will the difference be? can i just change the 2 speed to get some more top-end back?
#7495
Cheers
#7496
Re: MT12 flameout / high temps
Thoughts?
Thoughts?
Another thing to check may be your fuel.......bad fuel often causes flameouts at higher temps.
Cheers
#7497
Hey guys, thanks for the tips. I'll try a hotter plug and different fuel. The fuel I have runs fine in my AD2, but the MT12 doesn't get that hot... I think you guys are on to something.
Is 270 too hot for an MT12? Does any have experience with this motor and an NTC3?
#7500
Thanks guys. I put new 30% fuel and changed my plug. Flameout problems are gone. Oddly enough engine temps are down, too.
