Rc10ntc3
#6916
Originally posted by revzalot
The car has a bad habit of chunking the rear tires with the V2 suspension.
#6919
I'm running -4 camber in the rears. I also have too much steering in my setup.
#6920
Originally posted by soc123_au
Had a look at the TC4 pics & blurb. I dont think we will see a NTC4 for a while yet. The major improvments to the car seem to be taken from the NTC3.
#6921
I wonder what they're going to change because there's so many hop ups out there that can improve the NTC3. I wonder if they're going to make it CD3 like? It'll be lower cg and the engine can take any pipe. I hope they'll do better because AE is known for innovations. I believe they can do better. Time will tell. As for now, I'll race the crap out of my NTC3. The car has a bad habit of chunking the rear tires with the V2 suspension.
#6922
About V2 chuncking tires..............not my case, they just ran the same as V1.
#6923
Re: Centax
Originally posted by CHUCKMANDO
Hi Rookie,
We left off you were going to try the centax. Did it solve your slipping? I ran this weekend. As usual the ver1 ran well, but a few tanks into it someone stopped on the straight, didn't say anything and you guessed it, plowed him. Couldn't avoid it, was dueling with a jp 5 port driven kyosho which had a large top end. Only broke a pivot ball and a lower front arm. Not bad.
Ver 2 I set up pertty much like v1, but spun out during hard exceleration after a sharp right turn. Really had to baby it there. I ran 42's all around. Sure 40's in the rear would have solve it or my lola body, but I wanted to finish with my 42s since temp should soon start going down, and forgot the lola. Seems I will stick to diffs for now
Hi Rookie,
About your V2 V1 setup, good to hear that you are still getting good handling.....when I was racing last week with a broken pipe, OIL/FUEL is coming out from the bottom of the pipe then flew toward to the rear wheel........I lose good 3 laps because I was fishtailed on each hair pin corners......that is NOT FUN.
And for you........try 40 f/r or even 37f/r.............for me, faster lap times and a WIN are way more important then $20.
YES, it does solved my slipping problem..........25 minutes, 5 tanks NON STOP beating on the engine and running back and forward on a 100 feet straight kicking the 2-speed........at the end of the run, I still have the SAME SPEED of the straight compare to the first minutes, that means, the clutch is still kicking....
On Sunday race, my 2 shoes clutch was slipping after a 5 minutes main....I can tell because I didn't adjust nothing on engine and 2-speed but the car is definitely slower and the engine REV is so loud that I can hear that from the driver stand....
Now, I just need to use my good engine (x12) and put a NEW PIPE (I was testing the centax last night with a HOLE at the bottom of my dual chambered pipe....idling is very bad and I think it does some weird effect on the engine performance...) and test it on the track this Sunday.
#6924
Originally posted by spawn
just had my run today and yes I have a lot of steering too, so much that I am only using the front roll bar and removed the rear. Also running on 12degrees caster. What springs are you using for the front and rear? My suspension setup is purple front, red rear, both 60wt, front inner upper shock position while the rest is std position.
The more VERTICAL position of your shock, the less traction you will get.......in your case, you want less traction at front, more traction at rear....
Also, camber, my front was set at -2.5 and rear was set at -3.0....
If you are not using sway bar at rear....don't even bother to use it at front....that works even better.
#6925
Agree with you on this, glad they are making the hingepin a little thicker as the TC3 ones bend kinda easily. Anyway I hope the NTC3 will not be outdated in the next 3 years as its still a darn nice car to drive, race and bash.
I am sure NTC4 will not use the pivot ball hingpin design like the TC4, those are for electric Touring car to adjust toe and dive by replace or add spacerd and blocks........NITRO does not need to replace or add anything, they just need wrenching on the pivot balls or camber links.
I would like to see NTC4 with the revision pertaining to the previoius problems that can be found on NTC3...
(1) shock towers....make it 1 piece with the upper diff case or like 3racing, a 1 piece mounting with the upper diff case then use a carbon fiber shock towers.....
(2) Fuel tank....any mod is better to eliminate those bubbles...
(3) More top speed on gears option (22/29T..?)...also, please update their 0.8 module so we can use different tooth combo and not limited to 4 T or 6T onlys (like OFNA or Hongnor design....)
(4) RPM bumper and ball cups, STANDARD.
(5) Stronger chassis.....3mm at least.
(6) Thicker front pivot balls like old Serpent cars?
(7) Front and rear ROLL CENTER options.......well, at least, more on the front....so the NTC4 can have the same options like 710 or MTX or FW-05R.
(8) Tank protection (if NTC4 are still using the same kind of pipe)...just pick up 3racing carbon side brace and put AE tag on it like Yokomo 1-way....
(9) Centax as a Factory Team option.....and redesign the standard 2 or 3 shoes clutch shoes/clutch.
Not even have 10 things to mod..........and I think that is a more then enough RACE READY machine....
#6927
#6930
I'll continue testing with the above. I'm using yellow springs front and 50 wt up front as well. Stock caster setting and front middle shock position. I'm using rear inner hole camber turnbuckels. The car is loose which I like. On throttle steering is sweet. The only issue is the car gets too loose going into a turn.
