Rc10ntc3
#5326
thought so fuzz,that things garbage,did u use the kit pipe yet?an hey if any wants that pipe ill sell it for 25 bucks by the way.
#5327
#5328
Registered User
The dynamite pipe is too long. I have tried or made every type of pipe possible for the NTC3. Dennis came up with a center exhaust deal that I used for a good while till the RD pipe came along.
The RD pipes are by far the best out there right now. The turbo version works very well with my modded engines!
#5329
ok ,
so its getting a little colder here in p a, ok alot colder, last race was 80 degrees, now its in th ehigh 50's to low 60's and was wondering since this is my first season racing , and my car was setup in the warmer weatehr ,, do i need to soften the suspension for the colder temps,, or do i just use softer foam ,
i assume traction will be a problem in the colder months ,, and aslo why do the clubs in the colder climates stop racing in the winter outside,, id love to race outside all year ,
#5330
bbntc3,whats this center exhaust deal pipe your talkin bout,can someone enlighten me on that type of pipe?
#5331
Registered User
The center exhaust deal is something Dennis came up with when he was playing with the car. He made a pipe turn down the center of the car and exit out the rear of the car. He used a Rex pipe modded to rear exhaust outlet. I also used this pipe and a MIP Stinger pipe and a Paris ribbed pipe.
#5332
show me some pics
#5333
Registered User
There's a bunch of pics here back in the pages, but here is a few more.
#5334
Registered User
another
#5335
Registered User
one more
#5336
Registered User
another
#5337
Registered User
Fuel tank modd,(serpent).
#5338
Registered User
For some reason I and a few others had tuning and heating problems with high output engines, these exhaust systems and fuel tank modds cured most of my problems. Now with the RD pipes and the G-1 or G-2 chassis all problem are gone. This tells me there was a problem with the stock pipe and stock chassis.( chassis too flexy, too much vibration, and too much restriction on the pipe. I can't answer why some people have troubles while others do not. It seems the more HP you make the more troubles you had.
#5340
Originally posted by spawn
what caster angles are you guys running?
