Rc10ntc3
#4863
New Engine For my NTC3
I am looking for a new engine for my NTC3. I currently run a Nova Rossi MT12 and I want more power. What do you guys think of the RB X12 or the RB V12??
#4864
bro i think u should get a rossi motor the new black pixi
i went from an mt-12 to that and i noticed an immense power difference
#4865
MIP Clutch
Do any of you use the MIP clutches on your ntc3? If yes how is it? Thanx!
#4866
Re: New Engine For my NTC3
that engine is a screamer
it beats the MT-12 all around
especially in the mid-high end
#4867
Re: MIP Clutch
#4870
Thanx Old SKool. Also anyone else haveing problem with there screw that tighten the clutch bell together falling out, everytime when I run the car it get loose and yesterday it came off and causeing me to loose a bearing? Today I tried to use some thread lock hope that would help, if anyone else experinces the same problem, please help me out how to fix it? Help is very apperciated, thanx.
#4871
Registered User
I us alillte lok tite on the srew. But I went to a alllen head scre, does;nt stripp as bad. You do have it shimmed with alittle endplay?
#4874
Originally posted by hooked_on
oh... and how tight do you screw the shoes together?
1. Place your two clutch shoes together with the numbers side facing up. Slide #2289 adjustment spring onto #2289 adjustment screw. Insert the screw and spring into the shoes and tighten the screws until they are fully compressed. Be gentle! Now turn the screw 3 1/2 turns counter clockwise. Adjust both screws equally.
2. Slide your clutch Shoe assembly ontp #2286 input shaft
3. To adjust the pressure of the set screw: Adjust the set screws equally so that the ball is just touching the flats on the imput shaft.
NOTE: If the shoe assembly rocks on the shaft, tighten the set screws so the balls are touching the flats, but not enoughto spread the shoes apart. If the shoes start to spread apart, loosen the set screw to take pressure off the ball. Adjust both set screws equally!
I hope this helps.
#4875
rear toe in
is any body having trouble with keeping the rear toe set while driving their car because it seems like even if i have the slightest tap with that car that it throws my toe wickedly out of place
