Rc10ntc3
#3376
The mip is a 2 shoe with a wrap around spring right?
Its definately a more common and effective type of clutch than the finger type that is stock (if only they would make a 3 shoe... )and is definately the next best thing to the kfactory centax... (which is WAY beter than the kawahara one...)
#3377
Again FastHarry, yes I've been racing MTX3's...and to be perfectly honest, they're FAST. But they're still having teething problemsamd most mains I'm behind them at the start, but in front of them at the end.
#3378
I was looking in the extreme mag out now on the winternats and noticed that all the Mugen guys in the A were running 40% Anyone tried this? Does O'donnell make 40?
#3379
yes o'donnell makes 40%
#3381
A: Nitro Shoes are available in front and rear compounds. Even though the durometer number may be the same. The rubber is completely different. The durometer numbers reflect relative hardness among similar tires in the same foam family. The difference includes cell-structure, wear resistance, bite and price. Fronts have less bite but better wear. Rears have much more bite and slightly higher wear.
http://www.jacoracing.com/FAQ.html
#3382
Wouldn't 40% wear out an engine really fast?
#3384
Registered User
The chassis is based off the ntc3. It's actually based off the proto type chassis
Dennis Richey designed, but we have taken it a few more steps than he did. Its like 3.5mm in the middle of the chassis and tapers too about 1.5mm on the outer edges. with the tapered chassis theres no dragging the chassis on the edges, in high speed swooper turnrs.
Sorry guys no more pics until project is completely finished and tested.
#3385
Front tires have a smaller "cell" foam than rears do. I have never had a front tire work on the rear and vice versa...
#3386
BBNTC3... Do will it use the NTC3 Drive train? or what? PLEASE LET US SEE PICTURES!!!!!!!!!!!!!!
#3387
Registered User
The new chassis deal is 100% AE NTC3! Except for the chassis and upper deck.
I'm not letting anything else out about the deal right now, sorry! No offence to anyone, but I'm not releasing pics here for people to copy or hack on me about.
You guys will see the finished product about mid season, then you can judge it.
#3388
Ok i just got my ntc3 rtr my first nitro and it was a beautiful weather so i decided to break my engine with a friend it was 75* F and it wasnt raining perfect justa bit cloudy ok i had trouble at first fuel didnt go through in the carb so i opened the lid a couple of times then it flooded so i took out the plug and filter and emptied it out... ok so i read the break in etc then i got pebbles stuck in my spur gear and then my car wouldnt go and it started to overheat i think so i stoped it and i took them out and i started again well after it started to rain after the 3 tanks of breaking in so i stoped when i got inside i notice that the *clutch*( i think) its about 1 inch between the pinion and the flywheel it turned colors half of it now is blue and half of it is yellow what is my problem i wonder if i did it to hot my engine i made a mistake or something or is this normal car runeed smooth until the pebbles but im curious and worried about what happened? is this a big deal what should i do? what is it? i hoped i explained myself enough any questions feel free to ask i need your help thank you
#3389
try puncuating that paragraph again.....then maybe we'll understand wtf you're talking about.
#3390
I ran out of breath 1/2 way through it...
